Recommend gear ratio
Cmcintosh721
Post by Cmcintosh721 » Tue Aug 05, 2014 1:47 pm
I'm building a boat an have a 3 blade water walker 80" maximum prop an have a 400 small block complete roller motor around 475hp what ratio reduction unit should I buy
Birddog247
Re: Recommend gear ratio
Post by Birddog247 » Tue Aug 05, 2014 2:35 pm
I would first make sure what rotation the prop is. Left or right
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
Cmcintosh721
Post by Cmcintosh721 » Tue Aug 05, 2014 2:57 pm
Right hand rotation
Post by Deano » Tue Aug 05, 2014 2:59 pm
That part is easy.
If it is a Maximus, it is right handed. The left hand counterpart is the Sirius.
Gearing would depend on RPMs you are going to turn your engine.
If you're turning it about 5200 then a 2.3x gear would work.
If you're turning it about 5500 then a 2.5 gear would work.
If you're turning it more like 5900 then a 2.6x gear would be what you want.
Those blades should turn 2200 max at wide open throttle, a little more pitch and a less rpm is fine.
top engine rpm / 2200 (prop rpm) = gear ratio
And congrats on your prop ! You're gonna love the push. :thumbleft:
Cmcintosh721
Post by Cmcintosh721 » Tue Aug 05, 2014 3:17 pm
Thank you sir that's exactly the info I was looking for thank you
Cmcintosh721
Post by Cmcintosh721 » Tue Aug 05, 2014 3:25 pm
Does anybody know anything about the precision gear drives out of Oviedo fl
swamp rat70
Post by swamp rat70 » Tue Aug 05, 2014 4:30 pm
there decent boxs but only come in 2 to 1 ratio so would be little low at only 4400rmp on motor i had one of the first new big shaft ones he made , i was the test boat lol
BBC 502 ch3 2;1 whirlwind 76 stump puller 3 blade 16' laser with walk arounds .
Brotherbob
Post by Brotherbob » Tue Aug 05, 2014 5:10 pm
For whatever it's worth I run the same prop and about the same HP ,I run a 2.88 Stinger Gear drive in a 15' Air Ranger and its a real hot rod.
It turns lots o RPM 6200 to be exact and burns fuel but she can get up and run son. It's like a really fast bulldozer!LOL!
BB
BRAB41,TAA-220 ,Air Ranger 15x8 , SBC , 78 " 3 blade WW prop, 2.88 Stinger
SHO-NUF!
Cmcintosh721
Post by Cmcintosh721 » Tue Aug 05, 2014 10:05 pm
That is def a lot of rpms I'm thinking about keeping mine around 5600
Sniper
Post by Sniper » Wed Aug 06, 2014 7:11 am
2.68 is a great ratio
ptr34
Post by ptr34 » Wed Aug 06, 2014 9:55 am
I have a used 2.5 ballistic box for u. 2900
tons videos on YouTube ptr34
skinny99
Post by skinny99 » Wed Aug 06, 2014 10:18 am
ptr34 wrote:I have a used 2.5 ballistic box for u. 2900
That's a deal and a good combo for your 400. Lots of torque there most likely.
OLD MAN JONES
Post by OLD MAN JONES » Wed Aug 06, 2014 12:25 pm
Sounds like that 2.5 might be your Hucleberry :)
I'm betting you'll love it. Also it should keep your fuel burn down a tad and increase engine life expectancy by a fair amount.
JMHO...
LIVING FOR THE FUTURE OF OUR EVERGLADES..
WWW.MACKSFISHCAMP.COM A traditional cultural Gladesman property.
