400 sbc
jbtn
400 sbc
Post by jbtn »
What would ba a good set up for 400 sbcwith a 144 supercharger for dd use flat or dish piston rv cam or biger big heads or stock with 194 valves and 2 bbl or 4 bbl I think this is going to be my route some body out there has already done this im sure thanks
scottyroll
Re: 400 sbc
Post by scottyroll »
I don't think you need big high flowing head for DD even with a supercharger, I may be wrong. However, piston and head matching are always important things to consider. I think if you stay at 9:1 and below on compression you should fare just fine. I was going to pursue this route at one time. Hopefully, someone who has done it before will chime in.
:Scotty-Roll:
FLAwless
Re: 400 sbc
Post by John Fenner »
Smaller valve and runner heads, stock aluminum intake, rv cam, 450 Holley. You will need to calculate the best comp ratio for the supercharger.
ddriver
Re: 400 sbc
Post by ddriver »
john in a lot of your posts i see you recomd the 450 holly. have you ever ran one yourself? i have 14 rivermaster with rod boxes and small block chevy. 72 inch ww narrow set on 14. 600 eldo will snap to 3000 and get you out of trouble a lot faster than 450 holly. i have ran both.
Re: 400 sbc
Yes, snapped a 72/40 to 3000 hard. Plus the water walker stump puller has the same pitch in it that is now on a 520.
keebo
Re: 400 sbc
Post by keebo »
He recommends it because it is a good versatile carb, most people over carb
Just about everything anyway IMO. :fishing :D
:old_glory: :florida: :GA:
