383 SBC Carb ?
Patrick
383 SBC Carb ?
Postby Patrick » Mon Sep 29, 2014 11:54 am
Just wondering how big a carb [cfm] you all are running on your 383 chey engines. We have a 750 Holley vac secondary on ours. 14 foot Panther, 2.68 Rotator and Whirlwind 78 inch 3 blade, 13 inch wide. The motor makes about 425 h.p. Thanks Pat
nomad41
Re: 383 SBC Carb ?
Postby nomad41 » Mon Sep 29, 2014 12:23 pm
I'm running a SBC stroker with a 770 Holley with a 2.68 box with an 82" R set past the 3 mark tuning 5400
Treasurer FAA
Svcliche@yahoo.com
makinwaves
Re: 383 SBC Carb ?
Postby makinwaves » Mon Sep 29, 2014 4:17 pm
holley 750 DP on a 383 w/2:38box and 80" 3blade. runs great.
skinny99
Re: 383 SBC Carb ?
Postby skinny99 » Mon Sep 29, 2014 5:27 pm
Had a 383 making in low 400's for power. 2.68 box and 3 (R) blades set at almost 3 mark turning 5600. Had a really good working 600 cfm holley that was tuned and jetted properly. Installed a 750cfm Holley and picked up 200 RPM's at WOT. Calculator says it only takes like 570cfm but the built in prop dyno told a different story.
Re: 383 SBC Carb ?
Postby :) » Mon Sep 29, 2014 6:01 pm
Running 750 Holley on mine. 450hp
bonecollector
Re: 383 SBC Carb ?
Postby bonecollector » Mon Sep 29, 2014 11:05 pm
750 AED on all mine
Sensenich, Ox Drive gear box dealer 386-279-3712
BCConviber
Re: 383 SBC Carb ?
Postby BCConviber » Tue Sep 30, 2014 11:11 am
I had a 750 double pumper on mine.. When I rebuilt it the last time and pumped up the power
a little bit I couldn't jet it up enough to darken the plugs. I went to an 850 AED and jetted it
down a little.
aggiejim
Re: 383 SBC Carb ?
Postby aggiejim » Mon Oct 06, 2014 10:48 pm
bcc thats a gas hog I bet
16 x 8 floral city ls2 6.0 aluminun block 2.3 ch3
can u say addicted
16.5 x8 alumintech new build
6.0 ls2 2.3 ch3 3 blade
the aggie
Hammer00
Re: 383 SBC Carb ?
Postby Hammer00 » Tue Oct 07, 2014 10:32 am
Ive put 3 750 quickfuels on airboats 383, 383, 400ci and all 3 worked perfectly right out of the box. No adjusting other than the rear float level. Get the SS.
Motorheads Racing Engines
(941) 378-7033
HaulinGrass
Re: 383 SBC Carb ?
Postby HaulinGrass » Tue Oct 14, 2014 12:00 pm
I run a 750 DP Quick Fuel. on my 383 about 540 HP turning a 79 ex 2.7 ballistic box, had it up to 84.6 mph @ 6500 RPMs this Sunday :shock: still tweaking it tho
New (Hyper Airboat) 12'x7'6"deckover, 4??ci Water Thunder, 2.7 Ballistic Box, 3 blade whisper tip.. Faster than a Speeding ticket
Users browsing this forum: No registered users and 32 guests
