Making Progress
- DynaMarine
- Site Supporter - VIII
- Contact:
Re: Making Progress
Still drop the starter and it'd be easy to bolt right up
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
President/Owner
785.218.9449
www.dyna-marine.com
- digginfool
- Site Supporter - III
Re: Making Progress
blackwaterairboats wrote:No Shane he doesn't have a Jw he has the flexplate that comes with the Lsa.
I'm not sure who makes it but it looks just like the JW wheel. It definitely isn't what would be used in a car. Very heavy duty. Shane, you are correct. That makes all the sense in the world. I can't believe I didn't think of that. Thanks!DynaMarine wrote:Still drop the starter and it'd be easy to bolt right up
- digginfool
Re: Making Progress
I must say, that's a good looking gearbox!
One of the first things I noticed was how silky smooth the gears are when I turned it by hand. Once I got the old box off, just for comparison, I spun it by hand as well. It initially was very smooth then got progressively tighter until very tight, to the point I was pulling pretty hard on the drive plate to turn it. Then, suddenly got easy again. After a couple of pulls on the drive plate, the tightness returned and the process repeated, just to get easy again. Whatever the issue is, it's definitely on the driven gear. I have to imagine that when I blew the engine, tremendous loads must have been put on the gearbox; I was running WOT and it came to a stop in seconds. The inertia of the prop would have been enormous at that point and I could imagine teeth being deformed. So, with that being said, I suspect I was buying a new box sooner or later (probably sooner) regardless of what ratio I was running. I would also imagine that a good amount of power was being lost to the additional friction. We shall see next week!
Re: Making Progress
Ha Ha . . . There's all those dreadlocks again.
- digginfool
Re: Making Progress
Gives the boat that Caribbean character. Ya, mon. Irie, irie.Deano wrote:Ha Ha . . . There's all those dreadlocks again.![]()
Re: Making Progress
Maybe ya need a little Bob Marley art on the back of that starboard head.
Re: Making Progress
At some point, you are the answer man.digginfool wrote: I've been playing with pitch and I've had some mixed results. When I had it pitched for 5,200 RPM at the Freedom Ride, I managed to hit 59.8 mph, but that was on the skinny water on Lake Cypress. Deep water was around 54 mph with 4 adults. This past weekend, I took a little more pitch out so that I was turning 5,400 RPM. Boat did not like that. Cruise RPMs went way up and top speed dropped to 49 mph running trails in 2A. I spoke with the guys at Sensenich and was told it's more about pitch than propeller speed with the NGR. Those blades run best when pitched between the 2 and 3 mark. With my blades pitched for 5,200 RPM, the blades are right at the 2 mark, just a little above the 2 mark when pitched for 5,100 RPM, just below when pitched for 5,400 RPM.
- digginfool
Re: Making Progress
Had a little disaster and won't have any new information for at least a couple weeks.
Re: Making Progress
Damn , you have a grand wrapped up in wire loom.
" I have two guns...
One for each of you "
2011 Al David / AV 540
Re: Making Progress
What kind of disaster?digginfool wrote:Had a little disaster and won't have any new information for at least a couple weeks.
Re: Making Progress
Probably that socket set going thru the prop.
- digginfool
Re: Making Progress
Tony480 wrote:What kind of disaster?
What he said.Scarecrow wrote:Probably that socket set going thru the prop.![]()
Re: Making Progress
Man that sucks.digginfool wrote:digginfool wrote:Had a little disaster and won't have any new information for at least a couple weeks.Tony480 wrote:What kind of disaster?What he said.Scarecrow wrote:Probably that socket set going thru the prop.![]()
Broke.
Re: Making Progress
Especially, when the other guy just told you he picked everything up.dblj006 wrote: Man that sucks.
- digginfool
Re: Making Progress
Okay. So, now that I'm back up and running with the NGRs, the 2.5 box allowed me to add 3 degrees of pitch and 300 RPM sitting on the trailer over the 2.38 (5,400 RPM at 14 degrees pitch vs 5,100 RPM at 11 degrees, measured 4 inches in from tip of winglet). This is what I was hoping for; I got the engine up where it's making some more power, added quite a bit of pitch and prop is turning nearly the same RPM. Can't wait to see what kind of improvements I'll see on the water. Hoping for better cruise RPM, a little more snap and come out of the hole better. We'll see! Also, just made me smile to feel that smoothness over the Powershift. I'm sure the Powershift was the chit when it came out but it just doesn't match the NGR. Science!
- digginfool
Re: Making Progress
Found a baseline dyno sheet from Nickey Chevrolet on the Camaro SS, which uses the LSA with very similar numbers in stock configuration to the CTS-V. At 5,400 RPM, the engine is making ~520 HP and ~505 lb-ft torque. At 5,100 RPM, ~495 HP and ~510 lb-ft torque. So, that 300 RPM does make a difference.
- digginfool
Re: Making Progress
Finally got the boat on the water with the new box and my NGR. I have to say that this is without a doubt the right setup. I had the opportunity to run the boat light, heavy and through tall cattails and it is a beast. Not only that, but the snap is something I've never had before, even with the BBC. I can cruise deep water at 3,500 RPM, skim the grass at 2,900 RPM and when I stand on the go pedal, it will jump. I'll probably play with pitch a little but not until I run with the GPS so I can get hard numbers on what's happening, as far as cruise speed, top speed, mileage. If anything, I think it could use a little more pitch; maybe 2 more degrees but I don't want to pull the engine down too far. These LS motors seem to like WOT around 5,500. More to come later.
- DynaMarine
- Contact:
Re: Making Progress
Can't hardly go wrong with the 2.5 and strong LS
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
President/Owner
785.218.9449
www.dyna-marine.com
- digginfool
Re: Making Progress
Can I say 'motherf***er' on here?
I know shit happens and I have no doubt the issue is going to be taken care of but I swear; the airboat gods have something against my Diamondback.
Thank God I have my sled. At least I'll still be sliding for the next couple weeks until my boat's back together. I'm starting to believe the AC guys might be right about us CM boats.
Re: Making Progress
What happened now
- digginfool
Re: Making Progress
Changed the oil in my gearbox and a bunch of heavy filings and a broken tooth came out. Already talked to the manufacturer and I'm certain they'll stand behind their product but, dammit man! What are the odds?Tony480 wrote:What happened now
Re: Making Progress
Wow! That sucks. How many hours were on it? Hope you get it fixed soon
- digginfool
Re: Making Progress
19-1/2 hours. They said they would jump on it as soon as they get it but between the time to tear it down, pack it up, ship it, repair, return ship and re-install, I'm guessing it's going to be at least two weeks before the barge is running again.Tony480 wrote:Wow! That sucks. How many hours were on it? Hope you get it fixed soon
