going from gear to belt drive how close prop clearance
aggiejim
Post by aggiejim »
going from a gear box to belt drive what are the guidelines for clearance on rudders and transum welding now have 3 inches to rudders ???
thanks
16 x 8 floral city ls2 6.0 aluminun block 2.3 ch3
can u say addicted
16.5 x8 alumintech new build
6.0 ls2 2.3 ch3 3 blade
the aggie
aggiejim
Re: going from gear to belt drive how close prop clearance
Post by aggiejim »
guess its a tougher question than i thought :?
can u say addicted
the aggie
nebraskaairboater
Post by nebraskaairboater »
You should be ok with 3 inches... the prop will flex away from the rudders anyway. Only chance of them getting together is if you bump something with the rudders and if that happens you have other issues. Did you have any height issues going from gear to belt? My Rotator is quite a bit shorter from shaft to shaft than my dad's belt drive. If I made the switch and wanted to use the same cage I'd have to lower the engine quite a bit.
Dan
Dan Porter, Jr.
Fremont, NE
dragon2174
Post by dragon2174 »
I have 3 inches from prop to back of transom. so 3 inches should be fine. the biggest problem will be the fact that belt boxes are higher than gear boxes. I had to add about 6 inches to my cage to get the clearance I needed. so you will have to do some cage work to get it to work
happy harold
Post by happy harold »
nothing is written in stone. at least 4 inches, but no more than 6 has been a loose leaf standard for many decades. i just finished a boat and tried it out 3 weeks ago. i set it up for 4 inches, but when i put on this giant water walker prop i had a little over 2 inches clearance. after some swearing i took it out and tried it. steering is quicker, but works just fine. so try it--its called getting experience.
aggiejim
Post by aggiejim »
we had allready lowerd the engine mounts we used the corvett mounts super clean and easy I lowerd the center crank by 6 inches the biggest hurtle was that the belt box moved the axis in witch the prop runs on by 4 inches back must move the rigging foreward by 4 inches changing the waight load on the hull so I switched the gas tank directly under the engine and moved the battories foreward
i went from a bbc to a 6.0 aluminum motor loosing another 236 lb from the back of boat
according to my racecar scalesI moved the center waight 2 inches foreward gonna test tomorrow also added 3 jacks so I can fine tune hull
can u say addicted
the aggie
ls1airboat
Post by ls1airboat »
it should do real good..thats how mine is set up.
myronja
Post by myronja »
If you have any porpoising issues u can move the back of the motor up or down. Just a thought
TAA-436
15' panther 350dd 72"x30 Flordia Paddle 40mph-sold
16X7 Air Ranger 383 stroker 2:1 belt 78" powershift 3/8" poly 58.8mph had to let out
aggiejim
Post by aggiejim »
testing sunday ill let yall know
can u say addicted
the aggie
aggiejim
Post by aggiejim »
damm that boat ran great putting the last togeather and dam the bad luck set my prop at 2 1/4 stripped out the last bolt while torqing pissed me off so pulled off 3 blade and went with a 2 blade 80 inch set at well over 3 not near enough could flash to 6000 no prob boat handled like a dream hoping to get my new hub thursday for the big weekend on the red river :D
can u say addicted
the aggie
