383 Stroker question
kwowens1963
Post by kwowens1963 »
any of you guys out there running a 383 sbc stroker, my question is where do you run your max rpm at, I am running a 3 blade sensenich R blade on a 2.36 stinger reduction drive, I have mine where my max rpm is around 5250, is this too low, too high or just right?
2012 15x8 GTO 383 Stroker, 3 blade sensenich
"Don't Stop Believin"
RRAA #007
BRAB #54
Gangreen
Re: 383 Stroker question
Post by Gangreen »
If it is doing what you want keep it where it is at. I run a 350 with a 2.38 box and cruise at 3100. My hill running wot is 5200 and and I can go anywhere. Adjust accordingly.
Capt.Legg
Post by Capt.Legg »
Gangreen wrote:If it is doing what you want keep it where it is at. I run a 350 with a 2.38 box and cruise at 3100. My hill running wot is 5200 and and I can go anywhere. Adjust accordingly.
Are you running a 3 blade r prop as well?
GossB133
Post by GossB133 »
What kind of power are you putting out of your 383? What mark do you have your prop set to and what size prop?
16' Panther Aluminum hull with 3/8'' polymer, Stainless Steel Cage and rigging, single rear steer with a triple front, Full walk around deck, 377ci Chevy Stroker with a 2:1 Rotator Gearbox. 78" Whirlwind 3-Blade
Gangreen
Post by Gangreen »
Running a 8 blade turbo prop.
kwowens1963
thanks all of you guys for the responses, here is more info on my boat and motor, 15x8 aluminum GTO, 383 stroker, 474 HP at 5250 RPM dyno and 469 ft/torque, 3 blade R series, 82", stinger 2.38 reduction.
I guess my concern is that I know I can turn this motor more tan this but I have heard that the stroker motors run and stay together better at lower RPM's, my motor is brand new built by MAS, I just want to get the max performance out of my boat but engine longevity more than anything else
RRAA #007
BRAB #54
kwowens1963
RRAA #007
BRAB #54
PAINKILLER
Post by PAINKILLER »
What pitch are you set at for the rpm your turning and if it does what you want why change
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
Post by :) »
I keep mine down at about 5200. I run as low of a rpm as i can and still go where i need to go. If i get hung up i ciuld alway make an adjustment
loudmouse
Post by loudmouse »
Stay within the warranty limits. Not much is gained past where u r. Sometimes with the higher ratio(numerically lower) ratio u will gain a noticeable amount by decreasing pitch but it will also increase cruze rpm. IMHO the tradeoff isn't worth the extra wear unless u jus want to hear that engine rev.
Built and Tuned by Me
barhopper
Post by barhopper »
Mine does best at 5000 WOT. Running a 2.3 belt. Pitch is a little over the 2 mark on the 3 blade R.
Post by Deano »
Just out of curiosity, could you post the dyno graph for that engine ?
A friend of mine was asking me about peak torque and HP for one of those, and I didn't know.
I've known of a couple of them that were plenty strong enough, but he don't want to believe me. :?
odcjohn
Post by odcjohn »
what rpm was your peak torque made that what matters you might be able to run up at 5800 but might not be doing any good
HuntingBigun
Post by HuntingBigun »
2014 post guys
Bigun
http://www.krvsa.com
scrambletown
Post by scrambletown »
HuntingBigun wrote:2014 post guys
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
read for life
philippians 4-13
john 3-16
deuteronomy 22-5
leviticus 20-13
luke 6-37
