12ft hull with a stock dd LS 5.3 motor
tacyb
Post by tacyb »
Hi guys
im new to airboating and been learning alot from yall i have a 12ft hul with poly and a stock LS 5.3 motor going to run it dd im going to push the boat with a water walker 2 blade prop 70in Signature. how do yall think it will run
scottyroll
Re: 12ft hull with a stock dd LS 5.3 motor
Post by scottyroll »
Should run OK. Are you keeping the factory ECM or going with a carb? PM ls1airboat on here if you keep the injection - he knows the in's and out's of these engines from learning on his 5.3.
:Scotty-Roll:
FLAwless
tacyb
Post by tacyb »
im going to keep the stock ecm. do u think it will run dry thanks
scottyroll
Yeah, it should run some dry. What kind of hull? what thickness is the poly?
:Scotty-Roll:
FLAwless
tacyb
Post by tacyb »
not to sure about maker of hull title says homemade i dont think its a homemade hull its 12x7 has 18in sides and has that upside down v on the bottom of each side the poly is 1/4
ls1airboat
Post by ls1airboat »
location ?
jonstar
Post by jonstar »
ls1airboat wrote:location ?
is his location going to dictate how his 5.3 direct drive is going to run? :violent1:
12'6" Diamondback 350 SBC Direct Drive
scottyroll
Yes it actually does, because I know matt would gladly drive a reasonable distance to help him set up his engine right, it wont work at all if you don't know what your doing :violent1:
:Scotty-Roll:
FLAwless
tacyb
Post by tacyb »
im in houston i have it all running good waiting to get it back from muffler shop today then going to pitch the prop was just wondering what yall think it can do i never had a airboat b4 so its all new to me
Olf Art
Post by Olf Art »
Huge question: Is your LS an aluminum block motor? If it is, it probably won't take the thrust load of a prop.
tacyb
Post by tacyb »
the block is steel heads are not i talk to water thunder he said if i keep it stock should be fine
rick
Site Admin
Post by rick »
Just an FYI to avoid any confusion...I went ahead & merged the other identical thread in Airboat Talk with this one.
Rick
Olf Art
Post by Olf Art »
tacyb wrote:the block is steel heads are not i talk to water thunder he said if i keep it stock should be fine
Cool. Thunder is the man to talk to regarding anything LS. Should make a nice runnin boat. Let us know!
tacyb
Post by tacyb »
What rpm should I have the prop turning
Striker543
Post by Striker543 »
No more than 3,000. If you keep the boat light and set it up right, it should be able to do a little bit of dry ground.
zrackers
Post by zrackers »
It should run dry fairly well if set up right. I have a 12x8 and it will run some dry.
zrackers
Post by zrackers »
With a 4.3l Chevy. ^^^^
tacyb
Post by tacyb »
boat runs good and runs dry
ls1airboat
glad its doin good...congrats on your new boat.
