2015 LS AIRBOAT ENGINE SPECIALS (ADDED HP & TQ NUMBERS)
DynaMarine
Post by DynaMarine »
Since 2012 DynaMarine Performance Boats has enjoyed a strong partnership with Turn Key Engine Supply as both our companies share the same passion for pushing the envelope, improving existing products and offering the best customer service we possibly can.
Turn Key is no stranger to the LS market. For over ten years they've spent countless hours in the dyno room fine tuning their various packages for truly low maintenance performance engine packages. Because of their relentless pursuit of perfection, the are among the industry leaders in the LS swap and off road/marine marketplace. They currently hand build 800+ engines a year out of their Southern California facility and support customers all over the world. From mild 400hp LS 5.3L iron block budget motors to wild 900+hp twin turbo or supercharged LSX motors, TKE is you're one stop shop!
Each motor comes truly turn key, from fuel system to air cleaner, starter to JW Wheel flexplate...it's all included. Each motor comes completely broken in, dyno tuned and ready to run. Their motors have been proven in the Baja 1000, Best in the Desert Series, Trophy Lite & SCORE Series, and the Dakar. The top 6 rock crawler in the nation are all running TKE motors. These motors are built to handle the abuse!
Every single motor shipped has a build sheet, Dyno sheet (so you know exactly what your motor is making!!), detailed installation manual and a 1-year unlimited hour warranty for recreation. Commercial warranty available as well. Typical lead time on an engine is 6 weeks or less from time of order.
I'm excited about 2015 to say the least. The airboat industry is booming with innovation, the competition is outstanding and it's awesome to see the industry as a whole take leaps and bounds forward. With that said I'll get to the good part. For the entire year, we'll offer some amazing prices on these bad boys. Prices are EFFECTIVE IMMEDIATELY and will run through the end of 2015!!!
2015 AIRBOAT ENGINE LINEUP (***All prices include shipping within the US)
475HP@5800RPM /455TQ@4400RPM LS1/LS6 (All Aluminum) - $8,900.00
500HP@5800RPM / 510TQ@4600RPM 6.2L LS3 - $10,550.00
565HP@5800RPM / 580TQ@4600RPM 418ci LS3 - $13,850.00
615HP@6000RPM / 605TQ@4400RPM 427ci LS3 - $14,950.00
665HP@6500RPM / 600TQ@4800 440ci LS7 - $21,250.00
775HP@6000RPM / 715TQ@4500RPM 427ci Supercharged LS3 - $23,950.00
900HP@5700RPM / 905TQ@4600RPM 416ci Twin Turbo LS3 - $24,750.00
Motors Include:
Complete Accessories
  • 120amp 1-Wire Alternator
    Short Water Pump
    Serpentine Belt System
    Brackets and Tensioners
    JW Wheel Flexplate
    Starter
    Exhaust Gaskets
Complete Ignition - 5-Wire Hook-Up
  • Coil packs
    Spark plugs and wires
    MEFI ECM with TurnKey calibration (Holley HP and Dominator EFI available)
    Custom marine grade engine wiring harness
    Uses all OEM connectors
    Sealed Bussman Fuse Block and Relays Mounted on Motor
Complete Detail Package
  • Custom Cam
    Engine Oil and Filter
    K&N Intake Air Filter
    K&N Crankcase Filter
    Hardware kit
    Motor Mount Bolts
    Oil Temperature Sending Unit Port
    Water Temperature Sending Unit Port
    Coil Covers
    Cable Drive Throttle Body or Electronic DBW Throttle Body
    Installation Guide
Complete -AN Fitted Fuel System
  • EFI Fuel Pump Kit (Stage I, II or III)
    AN Fitted Fuel Rails
    Pre-Filter
    Post-Filter
    Fuel Pressure Regulator
    AN-6 & AN-8 fittings (AN-10 where applicable)
    O-Rings & Crush Washers
We're excited to have TKE on our team and the opportunity to bring their product even further into the airboat/marine industry! For compete repower or new builds we'll offer even deeper discounts if purchasing a "power package" including reduction unit and/or a prop!
For more information please call us at 888-235-1465 and we'd be glad to answer any questions and put some new LS power on the back of your boat!
:old_glory:
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
SteveReid
Site Supporter - VII
Re: 2015 LS AIRBOAT ENGINE SPECIALS
Post by SteveReid »
WOW!! The wheels are turning in my head!! 500 HP LS3 is a small block and I can just replace my 350 SBC? Don't laugh at me because I'm lost when it comes to LS's. I've owned 3 Corvettes a 67 442 Olds and my last Vette was a 1978 and I didn't work on them, just drove them and picked up beautiful girls lol.
SteveReid
Post by SteveReid »
unforgiven11B wrote:Steve you got a buyer (ME) for your current motor if you choose to go to the LS3.
OK, I have thought about making it into 500HP but at those prices that would be stupid.
WhirlWind Propellers
Post by WhirlWind Propellers »
Wow Shane, those are some excellent engine packages and prices! :thumbleft:
We have had many extremely satisfied customers with Turn Key Engines' quality and reliability.
-Patti
Tony480
Post by Tony480 »
How much more is the holley system? Let's compare Apple's to Apple's....mefi sucks goat balls for tuning
pierson skunkape
Post by pierson skunkape »
Appreciate all the specs. on these engines, quite impressive.....really.... read through the post and couldn't find anything on TORQUE........at what RPM's does the 500 hp model need to achieve to reach its 500 Hp. rating.. and secondly what would be the torque ratings on said motor in the 3,000 - 5,000 rpm range....reworking a 15x8 Hamant , no powerplant decisions yet.... :dontknow:
DynaMarine
pierson skunkape wrote:Appreciate all the specs. on these engines, quite impressive.....really.... read through the post and couldn't find anything on TORQUE........at what RPM's does the 500 hp model need to achieve to reach its 500 Hp. rating.. and secondly what would be the torque ratings on said motor in the 3,000 - 5,000 rpm range....reworking a 15x8 Hamant , no powerplant decisions yet.... :dontknow:
I'll go back through and add the HP/TQ info later tonight! Sorry about that!
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
simpleman
Post by simpleman »
whats the hp at the rpm
stroked470
Post by stroked470 »
Hmmmmmm, got my ole wheels spinning
DynaMarine
Tony480 wrote:How much more is the holley system? Let's compare Apple's to Apple's....mefi sucks goat balls for tuning
The Holley option runs $700-800 more and that covers the mechanical throttle body, wide band O2 sensors and ECM upgrade.
I love the Hoey system but most would be plenty happy with the MEFI 5. The last 427 we sent out with the MEFI system made 620hp and 605tq...wouldn't have made anymore with Holley, but the Holley is definitely a little more user friendly for self-tuning and future mods like nitrous.
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
DynaMarine
Re: 2015 LS AIRBOAT ENGINE SPECIALS (ADDED HP & TQ NUMBERS)
Added HP and TQ numbers for those of you that were interested.
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
DynaMarine
Here's a 440ci LS7 for our next build. Coil covers are not shown in the pic as they are not painted yet. Dyno sheet as well, 665hp and 605tq. Not too shabby for a small block screamer of a motor!
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
Tony480
Post by Tony480 »
Except 99% of the people don't turn their motors 6500...more like 55-5800....good thing there is a warranty. Hope they run better than the gray supercharged one. LoL
flying fish
Post by flying fish »
Tony480
The motor that you are looking at the dyno sheet posted is built for 55-5800.
You should hope your dyno sheet looks just like it. Try and match your cylinder head and chamshaft to mirror the dyno sheet posted. :)
Is the torque you want to mirror. JMO-
Tony480
Post by Tony480 »
They are posting 665 horse at 6500.. it's not that at 5500
90chevy396
Post by 90chevy396 »
THEY ARE SHOWING MAX OUTPUT OF THE ENGINE. WHY DO YOU ALWAYS HAVE TO FIND SOMETHING TO COMPLAIN ABOUT. IF IT DOESN'T INVOLVE YOU JUST CLICK A DIFFERENT POST NO NEED TO GIVE YOUR OPINION ABOUT EVERY POST YOU SEE.
Tony480
Post by Tony480 »
Because I can. Just pointing out facts. If your gonna post something at least make it relevant. Hell by the time you upgrade to a holley hp ecu and buy headers you could buy a motor from Dave. Just pointing out facts...it's not like it's some smoking great deal.
flying fish
That bitch can breathe. The torque is amazing. Again, JMO-
chuckitt@earthlink.net
Post by chuckitt@earthlink.net »
Turn Key Engines are good people. They are building us an LS3 Stroker that should be 580 HP at 5200 and 580 ft lbs @ 3200. The specs were furnished by my customer and they were excited about doing the build. We will use a OX Box 2.09 to one and a 4 blade Maximus 82 inch Prop. We hope to run 30 miles per hour at 2200 rpm on the engine. It is going on a 14 ft new style Rivermaster with Kevlar layup. Can't wait to get the engine.
Chuck
Scarecrow
Post by Scarecrow »
BREAKING NEWS--------TONY 480 IS PROMOTING WATERTHUNDER MOTORS-----SOON TO BE PRESIDENT OF SALES. :lol: :rebel:
DynaMarine
Here's a better one for you Tony...LS427 with a fat ol' torque curve. That's what we're really after though isn't it, after all HP is just merely a measure of the rate of torque production right?
As far as the LS7, well it's a tough SOB and in stock form held up to GM's 50hr WOT test and their 300hr peak TQ to peak HP test adjusting rpm in 125rpm increments start at 4800 up to 6300rpm. With a 7200rpm rev limit. 6600-6800 ain't a big deal. Titanium rods, valves, retainers and beefy lightweight springs help make that 7000rpm reliable. Not quite possible with factory L92/LS3 heads. Hell the LS7 heads flow 400cfm out the box...
You ask me, the 427 is the best bang for the buck...but I sure would like to rip an LS7 at 6600-6800 for 400'.
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
kjs427
Post by kjs427 »
Thats impressive Shane!!!! i would let the HEMI loose to run that :lol: :lol: :lol:
2019 DynaMarine Revo
448 C.I. Gen III HEMI
2.7 Ballistic
DynaMarine
kjs427 wrote:Thats impressive Shane!!!! i would let the HEMI loose to run that :lol: :lol: :lol:
It'd be a fun to run ya. Sure we'll see ya at Thunder. Not sure my 5.3L iron block budget build can hang with that HEMI :stirpot:
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
strokin05ct
Post by strokin05ct »
90chevy396 wrote:THEY ARE SHOWING MAX OUTPUT OF THE ENGINE. WHY DO YOU ALWAYS HAVE TO FIND SOMETHING TO COMPLAIN ABOUT. IF IT DOESN'T INVOLVE YOU JUST CLICK A DIFFERENT POST NO NEED TO GIVE YOUR OPINION ABOUT EVERY POST YOU SEE.
:cheers: thank you! Tony480 has got to be one of the most negative people on this forum. Its a shame no one can post a topic without him bashing them, proving them "wrong" or right, or just basically saying if you don't have what he has or thinks is cool than you SUCK! :violent1:
Cody
"she gone!"
GM 2.0 LHU Turbo Ecotec, stock engine, 78" whisper ex 3 blade
06 Hamant 13'
junglecat
Post by junglecat »
Look at the 5250 mark. Torque and HP is close to 600. That's the tell all rpm number. Impressive!!!!
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
