Expansion tank
SHOOTER250
Expansion tank
Post by SHOOTER250 » Sun Jan 11, 2015 6:10 pm
Can I replace my coolant expansion tank up on the cage with a filler neck expansion tank mounted on intake manifold . It's a jegs product 5 1/2 inches tall with all the outlets needed.
15 diamondback 425 hp 454 factory set up
Trying to get a engine cover made,it would work much better if I could condense that plumbing.
SHOOTER250
Re: Expansion tank
Post by SHOOTER250 » Mon Jan 12, 2015 8:03 am
Really could use some help here guys
Thanks!
skinny99
Re: Expansion tank
Post by skinny99 » Mon Jan 12, 2015 8:12 am
Post a pic or link to part and that will help clarify. But most likely if boat runs cool now and you add a different expansion tank,as long as system can burp air out you will be ok.
Re: Expansion tank
Post by John Fenner » Mon Jan 12, 2015 9:00 am
Yes, it will work fine, make sure you have a good catch can to keep the level in check.
SHOOTER250
Re: Expansion tank
Post by SHOOTER250 » Mon Jan 12, 2015 9:12 am
Thanks guys !
SHOOTER250
Re: Expansion tank
Post by SHOOTER250 » Mon Jan 12, 2015 10:21 am
Jegs billet filler neck expansion tank
Part. # 555-53111
