Sbc or bbc
Txmallymurker
Sbc or bbc
Post by Txmallymurker »
I am in the process of buying my first hull. It is a 16 x 7.5 alluminum with poly bottom. No rigging or stands. I'm getting a really good deal on the boat IMO. I am wanting opinions on what motor to go with as well as what belt drive and blade. I am wanting the most dry run power I can get... Speed is not what I need. And of course I'm not rich so the best bang for my buck is what I'm looking for thanks in advance :old_glory:
Afflicted
Re: Sbc or bbc
Post by Afflicted »
No replacement for displacement. I'd say bbc or Ls
Txmallymurker
Re: Sbc or bbc
I can get my hands on a 454 with mild cam for a pretty decent price... What about belt drive and blade? Any suggestions
akblackdawg
Re: Sbc or bbc
Post by akblackdawg »
Hate to say it, sounds like you are making some of the same mistakes I made with both of my boats, going as cheap as possible. Better off not having to buy something twice to end up with something that will work for you. There are bargains to be found, but be careful. I'd rather have a stout high performance SBC then a stock 454, but a built BBC will supply lots of torque. My choice would be a LS, and you can buy those used and upgrade for modest price, but need to know enough not to buy junk. Bud
Txmallymurker
Re: Sbc or bbc
That's why I am here on this forum. So I can keep from making mistakes like that. I am not wanting to go cheap. I will be building the boat a little at a time. But that being said I can't spend 10 to 15 k on a motor it's just not possible for me to do. A local engine guy claims to have a reman 454 that's pushing 600 hp for 5k. Supposed to be a "brother in law deal" he was building at home. Just not real sure what to do now.
Txmallymurker
Re: Sbc or bbc
That's why I said claims lol... It's hard for me to believe as well. I am wanting to buy the right motor. Just don't want to buy someone's junk and don't want to spend 10 to 15k... I know there is no industry standard with airboats . so what is your suggestion?
Txmallymurker
Re: Sbc or bbc
I know this is a stupid question but... When you say ls motor you are talking about a corvette motor correct... Like a Ls1-Ls7
Txmallymurker
Re: Sbc or bbc
Ok just making sure that's What you were talking about... I'll take a look and see what I can find
akblackdawg
Re: Sbc or bbc
you can also buy a 383 new, with warranty from Whites in TN, for under that 5k figure, i bought a 480 hp 496 crate for under 5k, but it didnt work out too well. I know some on here have spoken highly of Whites, and he will make a specific airboat motor. Bud
Txmallymurker
Re: Sbc or bbc
http://www.jegs.com/webapp/wcs/stores/s ... Grp=search
Would this Ls motor be a good choice? It is right around my price range and seems to be everything I need in one kit.
BGREEN427
Re: Sbc or bbc
Post by BGREEN427 »
16 ft boat and 327 horses would struggle on the ground. The sbc 604 crate motors are about the same price and have more horsepower, better parts. I think BBC 454 bored out 468, forged pistons, good rods or at least good rod bolts would be a solid start . Balance everything and spend what you have left on aluminum heads. I think it could be done for $5000 if you have a local machine shop you trust who has built airboat motors.
CactusJack
Re: Sbc or bbc
Post by CactusJack »
With a BB I would think that a gearbox reduction might be the way to go, rather than belt reduction, as the torque of the engine with a belt and the prop going the same direction will torque roll the boat more than the crank going one way and the prop going the other partially cancelling each other out, especially in slow turning and adding or reducing power (depending on which direction the turn) and the risk of dipping a corner.... Just my opinion, what do BB owners think? Any truth in that? :dontknow:
Everglades_Rebel
Re: Sbc or bbc
Post by Everglades_Rebel »
Well a big block will be a lot more expensive than a small block and will use moee fuel. On the other hand it will have more torque and pull a lot more boat. Small block will probably be cheaper and will use less fuel but will not have the torque of a big block. Both ways you'll need a gearbox most likely if you want to go over dry ground. If you're going to haul more than 5 people I'd say big block.
Last edited by Everglades_Rebel on Sun Mar 08, 2015 12:51 pm, edited 1 time in total.
:rebel: 2013 14x8 Diamondback Ultra Lite Hull, 400HP hopped up SBC, 2.38 Stinger Gear Box, 3 blade Sensenich 80' inch prop :rebel:
"Any society that would give up a little liberty to gain a little security, will deserve neither and lose both"
general1eye
Re: Sbc or bbc
Post by general1eye »
How much does an all aluminum big block weigh?
Everglades_Rebel
Re: Sbc or bbc
general1eye wrote:How much does an all aluminum big block weigh?
It depends on the motor but probably around 500 pounds
21DiamondB
Re: Sbc or bbc
Post by 21DiamondB »
The LS motor is going to cost you alot more money in the end than a big block will with enough horsepowerr/torque to get the job done. Sounds to me like you are really trying to build this on a budget. With that being the case I'd go with a 454 425hp BBC. It's not the most ideal engine out there, but neither is your budget. I've had that one a 20' boat that would run dry and get the job done. Eventually I wanted more, as always and stepped up to a different boat with bigger horsepower. The next step up is another three grand.
-------- 16.5 x 8 Diamondback - 632ci - Oxbox 2. 55 - Sensenich 5-Blade JX---------
Txmallymurker
Re: Sbc or bbc
Well more money will just take more time. My first thought was to go with a 454 just for the fact that they've been around a while and they make a decent amount of tourque and hp. I would like to spend 10k on a motor it's just not reasonable for me to do at this point. I have to keep in mind that I still have a lot of money to spend even after I purchase a engine. Thanks everyone for your thoughts. Im sure I'll be posting more stuff on here as the build goes on.
21DiamondB
Re: Sbc or bbc
I wouldn't spend the money on a 454 that someone says has this and that. Spend it on a crate 454 with 425hp so you know what you are getting.
21DiamondB
Re: Sbc or bbc
He said he's not looking to spend 10K on a motor right now, hence the reason I would recommend the 454.
jopete
Re: Sbc or bbc
Post by jopete »
a 454 gm crate motor, 2 to 1 belt drive, demon carb, and a 15x7 porie' hull will go just about anywhere with a few people and supplies. and it won't break the bank.
good luck
Txmallymurker
Re: Sbc or bbc
Was planning on belt drive since they seem to be a little cheaper.... Was planning on getting a good 3 blade prop and as big as I can get away with.
Lwells
Re: Sbc or bbc
Post by Lwells »
My suggestion would be no matter how you go make sure that the engine you buy has all forged internal parts which marine engines usually are for I don't know about airboats but I've found in the past lots of people would let their marine boat engine freeze and bust (up north) and would buy an auto engine trying to save money and in no time would blow the auto engine for they aren't built to take the punishment a forged engine will. You guys fell free to correct me if I'm wrong.
21DiamondB
Re: Sbc or bbc
Stick with a 78" three blade if you have room for it. Panther sells the marine crate engines as well.
Txmallymurker
Re: Sbc or bbc
I'll be building all new rigging from ground up... Going to go with stainless... Plan is to get engine then reduction then prop... Then I will build rigging to fit what I have.
Txmallymurker
Re: Sbc or bbc
Figured I would make it clear a 80" prop and call that good... Pretty sure that's all the clearance I'll need... But the rigging is a whole different ball game I understand that. I'll just have to cross that bridge when I get there. ... I'm sure I'll need some input when I start that project
