Chevy big block dd on a 13'6 hull ?
Shippee123
Post by Shippee123 »
Opinions, was planning on a small block but the motor is practically being given to me and all's I have is the build cost.
Thanks in advance
Re: Chevy big block dd on a 13'6 hull ?
Post by Deano »
I would put that in the why ask why category. :D
Unless it is some really antiquated, obscure engine to get parts for, it may be the better choice anyway.
What is it? There may be some better than others, but I would prefer a couple over a DD small block.
** EDIT ** Somehow I missed the Chevy in the title. I was thinking Caddy, or maybe Buick. :roll:
As Joe accurately points out, they are heavy and don't produce an advantageous power/weight ratio.
I sit corrected. :oops:
Shippee123
1993 454
Joe
Post by Joe »
A vortex 350 with a good cam upgrade will by far out perform the BBC in a DD application. There's a reason you don't see many BBC DD boats,power to weight just isn't there in a DD application.
Compromise is for those that cant get it done!!
Equal rights for Southern Whites!
Shippee123
Does a cam upgrade help or still just not a good option?
Joe
Post by Joe »
Imo it's not a good option for DD. Now with a gear box there a contender. I run a 454 gear box boat.
