MR Kendall's 442cui WaterThunder motor.
Waterthunder
Post by Waterthunder » Fri Apr 03, 2015 5:11 pm
Normally when we build one of these beasts the customers demands we keep it all under wraps. Mark said we could use his build for a article so we figured what the heck mis well put it up on Southern. You know some engine porn. So here is the run down we are building Mr. Kendall a 442 cubic inch fuel injected LS. It is based on the GM LS7 block which we will hone with the mains fully torqued and a torque plate on the deck to a 4.130 bore. (because the new factory bore is about as round as a square peg) then we will be utilizing a Callies 4.125 stroke crankshaft. Here is a picture of that sweet little LS7 block which came sealed for our protection.
we will post some crank and rod pictures Monday along with our assembly.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
swamper2
Re: MR Kendall's 442cui WaterThunder motor.
Post by swamper2 » Fri Apr 03, 2015 5:28 pm
it will be nice to see the wizard at work. thanks
Tony480
Post by Tony480 » Fri Apr 03, 2015 6:00 pm
Sweet...wish i had one of those big inch motors..guess I'll stick with the junkyard dog
PAINKILLER
Post by PAINKILLER » Fri Apr 03, 2015 6:56 pm
Some big power on the way oh how did the lsx 454 turn out
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
Waterthunder
Post by Waterthunder » Sat Apr 04, 2015 11:37 am
The LSX ended up in a amazingly perfect frame off retro resto 1969 Chevelle. We were building a LSX 502cui for a airboat but Callies is so back logged on the 4.600 stroke cranks the customer couldn't wait. We are installing a set of Brodix heads on this 442, I really think she will run noticeably stronger than Bronsons motor. Brodix has a LS cylinder head that I think will be perfect for our 442cui combo. We will post pictures of the whole build.
321-508-5316
Waterthunder
Post by Waterthunder » Sat Apr 04, 2015 11:39 am
Whats a matter Tony are you still concerned one of the Eco Techs is going to smoke you. Im sure your junkyard special will be more than enough motor for them import guys.
321-508-5316
PAINKILLER
Post by PAINKILLER » Sat Apr 04, 2015 12:26 pm
Waterthunder wrote:The LSX ended up in a amazingly perfect frame off retro resto 1969 Chevelle. We were building a LSX 502cui for a airboat but Callies is so back logged on the 4.600 stroke cranks the customer couldn't wait. We are installing a set of Brodix heads on this 442, I really think she will run noticeably stronger than Bronsons motor. Brodix has a LS cylinder head that I think will be perfect for our 442cui combo. We will post pictures of the whole build.
Lsx should move a chevelle ok do know it needs eaton gears moser axles Richmond 6 speed never have used callies know there better then the eagle
jimmyflfr
Post by jimmyflfr » Sat Apr 04, 2015 4:10 pm
Oh Jeeze mark is gonna be the baddest bit$h in the jungle soon!
glades cat
Post by glades cat » Sat Apr 04, 2015 5:01 pm
Geeze Dave, a nearly square motor. 8)
I know you guys are gonna build another interesting power package.
Another fast boat in the making...
PAINKILLER
Post by PAINKILLER » Sat Apr 04, 2015 6:41 pm
Been working all day so I'm little slow you said a 69 chevelle dave that yr has no style at all 70 looks 10 times better and callies is not the only crank company there are others
fl cracker
Post by fl cracker » Sat Apr 04, 2015 8:27 pm
^^^ pain I'm sure Dave is aware of that.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
PAINKILLER
Post by PAINKILLER » Sun Apr 05, 2015 9:30 am
I just figured him being busy might have slipped his mind :lol: :lol: :lol: :lol:
Post by SWAMPHUNTER45 » Sun Apr 05, 2015 9:49 am
Sounds like a cool build.
PAINKILLER
Post by PAINKILLER » Sun Apr 05, 2015 9:52 am
Does like to see how the brodix ls heads do have thought about using them myself on a motor
kjs427
Post by kjs427 » Sun Apr 05, 2015 9:56 am
Waterthunder wrote:Whats a matter Tony are you still concerned one of the Eco Techs is going to smoke you. Im sure your junkyard special will be more than enough motor for them import guys.
Ya dave how's that junk yard motor of Tony's working out??
2014 DynaMarine EVO
426 C.I. Gen III HEMI
2.7 Ballistic
Tony480
Post by Tony480 » Mon Apr 06, 2015 6:11 pm
Working out damn good...pulled it in Saturday because the oil pressure gauge said 0 . Turns out it was the sending unit...put a manual on it today and has great pressure..why you want some of it...
Post by Deano » Mon Apr 06, 2015 6:17 pm
Boy, if there was ever a time to welcome a bad sending unit, that must have been it. :wink:
Tony480
Post by Tony480 » Mon Apr 06, 2015 7:24 pm
You ain't bullshitting
DynaMarine
Post by DynaMarine » Mon Apr 06, 2015 9:03 pm
0 oil pressure make ya chit bricks in a hurry. Glad to hear it was just a sending unit. Easy swap out and back in action.
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
Waterthunder
Post by Waterthunder » Tue Apr 07, 2015 9:21 am
The vibrations from the big props kill the electric sending units. I see it all the time. I had a few times I was out in the bone docks and my sender went bad. I just removed it cranked the motor and saw oil squirt 8 feet in the air. Then I put it back in and drove it home because I knew I had oil pressure. Man Tony looks like some people got excited at the thought you might have hurt your motor. I guess some people will be dissapointed you didnt have a serious problem. I personally am happy to see it was a bad sending unit.
321-508-5316
Tony480
Post by Tony480 » Tue Apr 07, 2015 9:26 am
Oh me too..guess the haters will have to find something else. LoL..I'll be following this build for when i upgrade
Post by Deano » Tue Apr 07, 2015 9:40 am
Waterthunder wrote:. . . Tony looks like some people got excited at the thought you might have hurt your motor. I guess some people will be dissapointed you didnt have a serious problem. I personally am happy to see it was a bad sending unit.
If you're implying that I am a member of "some people" you are mistaken. I only meant to convey
that, I to, appreciate the relief generated by confirming a bad sending unit; especially in this case.
Tony480
Post by Tony480 » Tue Apr 07, 2015 10:09 am
It wasn't directed to you Deano
Post by Deano » Tue Apr 07, 2015 11:01 am
Good deal. 8)
digginfool
Post by digginfool » Tue Apr 07, 2015 11:20 am
Waterthunder wrote:The vibrations from the big props kill the electric sending units. I see it all the time. I had a few times I was out in the bone docks and my sender went bad. I just removed it cranked the motor and saw oil squirt 8 feet in the air. Then I put it back in and drove it home because I knew I had oil pressure. Man Tony looks like some people got excited at the thought you might have hurt your motor. I guess some people will be dissapointed you didnt have a serious problem. I personally am happy to see it was a bad sending unit.
Interesting. On the LSA, there are two temp sensors; one for the computer, one for the dash. Is that the same for the oil pressure as well (I only see one external)? If not, then I would assume that should the OP sensor fail, the engine is going to shut down. Would it behoove someone to keep an extra on board just in case?
