Cam timing question
Shippee123
Cam timing question
Postby Shippee123 » Thu Apr 23, 2015 10:45 pm
Will advancing the cam timing 4 degrees on a stock bb chevy dd help bottom end torque at lower rpm ? Or is it best left alone ?
THANKS !!
glades cat
Re: Cam timing question
Postby glades cat » Thu Apr 23, 2015 10:49 pm
Yea, advancing the cam lowers the power band, retarding the cam raises it.
digginfool
Postby digginfool » Thu Apr 23, 2015 10:59 pm
Careful though. Too much advance will lead to detonation.
Shippee123
Postby Shippee123 » Fri Apr 24, 2015 12:38 am
Ok thanks, wasn't sure if it was worth doing on a stock engine.
Thanks again
Whitebear
Postby Whitebear » Fri Apr 24, 2015 5:07 am
We used 3 degrees on the 455 Buicks. Worked like a charm.
crowhater
Postby crowhater » Fri Apr 24, 2015 3:30 pm
I have used 3* advanced on 500 Caddy motors many times.
Users browsing this forum: kwanjangnihm and 20 guests
