cam company ?'s
josh_2562
cam company ?'s
Post by josh_2562 »
Hello
I may have to replace my cam due to dist drive gear being worn out. Are there any cam companys i shoukd stay away from? Who do y'll recommend? Thanks for the help
PAINKILLER
Re: cam company ?'s
Post by PAINKILLER »
I use crower never had a problem with any of there cams
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
skinny99
Re: cam company ?'s
Post by skinny99 »
Comp cams are on there game.
josh_2562
Re: cam company ?'s
Post by josh_2562 »
Do I need to replace my roller lifters?
air-roberts
Re: cam company ?'s
Post by air-roberts »
do you have a brass or milonized gear on distributer? thats what it sounds like other that cam and is is it a roller?
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
josh_2562
Re: cam company ?'s
Post by josh_2562 »
According to msd the dist gear is milonized (spelling) yes the cam in the engine now is a roller
flying fish
Re: cam company ?'s
Post by flying fish »
Josh
Ultradyne/Bullet for custom airboat grind. JMO-
Bullet and Ultradyne have combined and I would suggest talking to Mark with all your tech questions and cam choice
Lots of info to gather.
Mark (662) 893-5670
Tony480
Re: cam company ?'s
Post by Tony480 »
I would call comp. I called them all when i was building mine and got the most help from comp. Called bullet several times and got different answers each time. Really happy with the cam i have now
flying fish
Re: cam company ?'s
Josh
Your new camshaft needs to be degreed/phased proper.
very important. JMO-
Springs-
Installed Height and seat pressure.
Spring pressure over the nose or @ max lift.
Dead stop
Dial indicator
Degree wheel.
Check LSA compared to cam card.
Degree -ICA to manufacturers suggestion.
If you dont know and approach in this manner, she will probably not survive.
Not an easy repair you are up against. Extremely technical.
I suggest you remove engine & take to a reccomended mechanic with a a good reputation earned
flying fish
Re: cam company ?'s
I can go on about camshaft base circle and lifter length matching base circle, con rods clearancing cam lobe .050" minimum & knowing how to check proper valve train geometry then choosing proper push rod length to make geometry correct.
You want her to live, do it right. Cut no corners.
I am suggesting this process is difficult. Again, extremely technical.
Re: cam company ?'s
Like Tony I have gotten awesome support from CompCams
