Oil Cooler on 383 ? losing pressure
HaulinGrass
Post by HaulinGrass » Mon Sep 21, 2015 1:51 pm
I have had a problem with my oil possibly breaking down and losing pressure after only a few hours of running with new oil,( Brad Penn Green 20w50 and then tried Amsoil dominator racing oil) motor was recently rebuilt with a bigger cam and victor jr intake, about 525 HP previous motor did not do this. I am told it could need a oil cooler? and also told carb could be too lean and getting the oil too hot , water temp runs 150 all day. my next guess is to send oil sample out to be tested to see whats happening to it after 3 hours. could be getting fuel in it? the first 3 hours of running pressure is 75 PSI, I have changed the oil 3 times in 3 trips out, still does it. Any help would be appreciated.
New (Hyper Airboat) 12'x7'6"deckover, 4??ci Water Thunder, 2.7 Ballistic Box, 3 blade whisper tip.. Faster than a Speeding ticket
Rich Andrews
Re: Oil Cooler on 383 ? losing pressure
Post by Rich Andrews » Mon Sep 21, 2015 2:46 pm
Might need another viscosity rating? That new motor build might be just fine with the flow its getting but nobodys ok w low pressure..tuff call hope U get it figured out
What kind of oil pan U running, you have a HV pump?
LOHA is AHOL backwards
HaulinGrass
Post by HaulinGrass » Mon Sep 21, 2015 5:29 pm
Its a drop down Pan 8 qts to fill it, HV pump , great pressure for 2-3 hours then starts to fluctuate. it will drop to 20 psi when hard on the gas then rise back up when let off.
makinwaves
Post by makinwaves » Mon Sep 21, 2015 5:35 pm
Cheapest thing to try first is the sending unit.
Rich Andrews
Post by Rich Andrews » Mon Sep 21, 2015 5:37 pm
I'm definitely no expert, but sounds like your occasionally getting a lot of oil above the pick up and causing the fluctuations. Mine's real sensitive if I get .5 qt low and will do the same thing.
Are you coming back in w the same amount of oil or loosing it to blow by?
HaulinGrass
Post by HaulinGrass » Mon Sep 21, 2015 5:46 pm
forgot to mention that I installed a second pressure gauge (Mechanical) when I started having this problem. they read within 10psi
it burned about 3/4 of a qt on the days run Saturday, just above the Add mark. I will be glad to add a oil cooler if i can determin this is the problem
but id rather not have it if its not the issue. when I was in Kissimmee 2 weeks ago I added oil when this happen and did not help.
Rich Andrews
Post by Rich Andrews » Mon Sep 21, 2015 6:13 pm
Can you make the pressure go up or down while driving it? Rocking it side to side? Or does it just stay at a constant?
skinny99
Post by skinny99 » Mon Sep 21, 2015 9:10 pm
Sounds like a cracked pickup.
HaulinGrass
Post by HaulinGrass » Tue Sep 22, 2015 10:01 am
I thought about a possible cracked pick up tube, but I cant understand why it would work for the first 2-3 hours perfect (with new oil) and then start fluctuating..
Im puzzled :banghead:
glades cat
Post by glades cat » Tue Sep 22, 2015 10:38 am
Was the pickup tube welded to the pump?
If so, did they remove the bypass spring before welding?
jmpeter9
Post by jmpeter9 » Tue Sep 22, 2015 10:55 am
I was having the same issue with my Cadillac motor. I had good oil pressure all day long and then towards the end of the day my pressure started jumping up and down. I thought it was due to losing some oil to blow by. When I dropped my pan to replace my dipstick tube I noticed that the bracket that bolts the pickup tube to the main keep was broken so my tube was just bouncing around inside and once I fixed that I have maintained steady pressure. Hope this helps.
13'7" Laser, Cadillac 533, Stinger 2.38, 3 Blade Water Walker Maximus
Rich Andrews
Post by Rich Andrews » Tue Sep 22, 2015 11:40 am
as scary and crazy as it sounds, could be a well built motor getting all the flow it needs... but i'd b scared to shit running it
glades cat
Post by glades cat » Tue Sep 22, 2015 1:01 pm
Lack of lubrication/oil pressure will ruin your engine at high RPM.
All you need is 10psi/1000rpm. A stock pump will more than supply it with a tight engine.
If you want to save your engine, find the problem. Sounds like a supply problem.
High volume oil pump with poor drain-back can deplete oil level in the pan at extended high RPM. Was the lifter galley flashing removed?
Some high-end distributors with double o-rings can block the drain-back also.
If in doubt, take the pan off and take a look at the pump and pickup assembly.
HaulinGrass
Post by HaulinGrass » Tue Sep 22, 2015 3:35 pm
Thanks for all your help , Im gonna look into some of these suggestions, when I find the problem ill post on here..
HaulinGrass
Re: Oil Cooler on 383 ? losing pressure (
Post by HaulinGrass » Mon Oct 26, 2015 5:38 pm
I think the problem is solved,
I spoke to a very Knowledgeable Motor Builder on here, He suggested I might be running too much oil, ( wrong dip stick) causing the crank to spin in oil and foaming or throwing it places it shouldn't. So I drained the oil and put 6.5 qts in my 7qt pan to start with. Well this weekend was the Third time out running the motor 50+miles each time, No more fluctuation in oil pressure... So Far so good.. Now ill just cut the dip stick tube to match the amount of oil I put in..
