Caddy parts
zrackers
Caddy parts
Post by zrackers »
Does anyone have a good source for used caddy parts? I specifically need the lightweight stamped pulleys and timing indicator. I've looked at the aluminum pulleys but I just can't justify paying that much for pulleys.
Re: Caddy parts
There are no cheap 500 parts anymore.
Your gonna need to find a Junkyard 425 and they will probably want $100 to $150 for the take offs that half the time are rusty crap you have to take off yourself.
Try TREX he has a MTS combo
zrackers
Re: Caddy parts
Post by zrackers »
I am in OK. Thought it would be easier to find parts here but all the yards just scrapped them when scrap prices were high I guess. I'm about finished with this engine, I just need a pulley/timing indicator set. Guess I may have to bite the bullet and go with aluminum.
crowhater
Re: Caddy parts
Post by crowhater »
Look at purchasing small block chevy, big block chevy or Ford parts and having a local machine shop turn them to fit your crank. I don't remember off the top of my head what part is the best choice to have machined. I have done this is the past, I have even had Small block distributers cut down for my Cadillac so I could run MSD back in the day.
zrackers
Re: Caddy parts
Post by zrackers »
By the time I go through all that I'm better off to just buy the pulley set from MTS.
Re: Caddy parts
That was what happened here as well. The recyclers saw fast cash to crush the big cars so couple that with a demand for parts and you quickly see why a caddy engine is expensive.
zrackers
Re: Caddy parts
Post by zrackers »
I can't complain. I'm about 3500 in a complete rebuild. That's all accessories and headers. But I built basically a stock engine. New valves, cut the seats, decked the heads, didn't port/polish. May do that later if I need more power. Have the billet pillows and alt bracket on the way.
Bdriller
Re: Caddy parts
Post by Bdriller »
Look in my pics at pully set up for caddy comes with pullys new alternater, belt and idler, got 300 hrs on so far with no issues also its serpentine
Re: Caddy parts
I like the way you did that Driller with the idler and all....!
What was your cost of the project
Bdriller
Re: Caddy parts
Post by Bdriller »
alternater is the most expensive part new around $100. , idler $24 ,pulleys 15 - 20 we machine both pulleys slightly, the hardest part is drilling out the tensioner hole from 3/8 to 7/16 and apparently that's a trade secret, we are thinking of possibly marketing this setup, have not ran one on a belt or gear drive yet but I don't anticipate any problems, because of the small proximity of all components there is little to none vibration or belt flop, belt tensioner we fabricate from right and left threaded heim joints.
12PSI
Re: Caddy parts
Post by 12PSI »
Bdriller wrote:Look in my pics at pully set up for caddy comes with pullys new alternater, belt and idler, got 300 hrs on so far with no issues also its serpentine
How do I get into your pics, I've never been able to figure that out.
Bdriller
Re: Caddy parts
Post by Bdriller »
look in automotive only threads I posted a pic titled buick and Cadillac lovers
John C
Re: Caddy parts
Post by John C »
Here ya go. this should be the pic your looking for
John C
Re: Caddy parts
Post by John C »
Maybe its this one
Bdriller
Re: Caddy parts
Post by Bdriller »
John C wrote:Image
Maybe its this one
its both the second pic is my sons , hes a better painter than me :scratch:
