Caddy 500 parts question
zrackers
Post by zrackers »
Has anyone here used the March 2150 pulley set on a caddy. It has a two grove water pump pulley. Not sure why. Also the diameter is different than stock and there is no associated timing indicator.
Re: Caddy 500 parts question
Post by Deano »
Not specifically familiar with those, but in an OEM application a
second belt ran the power steering pump and/or AC compressor.
Some years additionally ran an air pump. Different years had different
pulley configurations, but as far as I know all ran more than just an alt belt.
happy harold
Post by happy harold »
I think cad pump pulleys are the same bolt pattern as ford. (if I remember right)
Are you trying to go serpentine?
March makes a Caddy set up but it is a polished Billet and a small fortune!
The number given is one digit off from a cheap SBC March kit which wont work.
There is a guy on here from Texas think "welldriller" is handle and he has put together a Caddy kit.
Post by One Eyed Gator »
Swamp He goes by bdriller. He did just put together a nice set-up.
T-rex has some nice Caddy parts in the classified for decent prices.
Bdriller
Post by Bdriller »
pics are in post called caddy parts posted November 27
