454? On DB hull
eazy89
454? On DB hull
Post by eazy89 » Tue Mar 15, 2016 7:51 pm
Looking to do an economical build. How you think a 400hp 454 on 14x8 DB hull with a 2.38 and 2 blade R will run? I seen a similar boat that ran damn good but wasn't sure of the HP. Any input
loudmouse
Re: 454? On DB hull
Post by loudmouse » Tue Mar 15, 2016 8:18 pm
I think a 3 blade R would be better suited to push that boat with a big block.
Built and Tuned by Me
Joe
Re: 454? On DB hull
Post by Joe » Tue Mar 15, 2016 9:07 pm
That's basically my boat,it'll run damn good!! But you'll need atleast a 3 blade,2 won't do it if it's 500hp
Compromise is for those that cant get it done!!
Equal rights for Southern Whites!
Joe
Re: 454? On DB hull
Post by Joe » Tue Mar 15, 2016 9:12 pm
Damn,forgot how to post a pic. Lol. There's a decent pic of mine on page 5 of my gallery titled my boat. It's 14 x 8 dB 454, 3 blade S. Goes where I want no problem. You'll love it,very stable and fun!!
Bdriller
Re: 454? On DB hull
Post by Bdriller » Wed Mar 16, 2016 12:14 am
If its a dun deel roll with it , otherwise a 454 isa turd in a blanket, much better choices out there!
Joe
Re: 454? On DB hull
Post by Joe » Wed Mar 16, 2016 1:29 pm
Turd in a blanket huh? Lol. What makes you think a 454 is a turd in a blanket? Cause I can promise you mine is no turd.
akblackdawg
Re: 454? On DB hull
Post by akblackdawg » Wed Mar 16, 2016 7:06 pm
save a couple hundred lbs and better fuel econ if you went with a 383
John C
Re: 454? On DB hull
Post by John C » Wed Mar 16, 2016 7:35 pm
Here ya go.
Bdriller
Re: 454? On DB hull
Post by Bdriller » Wed Mar 16, 2016 7:42 pm
Joe wrote:Turd in a blanket huh? Lol. What makes you think a 454 is a turd in a blanket? Cause I can promise you mine is no turd.
Only mean theres much better choices,
loudmouse
Re: 454? On DB hull
Post by loudmouse » Wed Mar 16, 2016 9:02 pm
Nothing wrong with a BB. It needs to be built to produce the power its capable of. Stock form an LS would be a better choice with more power and less weight. On BB with a compression increase, head change, cam, intake, carb and headers 600 hp is pretty easy.
eazy89
Re: 454? On DB hull
Post by eazy89 » Thu Mar 17, 2016 7:35 am
Yeah can't drop big money on a motor yet. So I was thinking ride it until the motor blows then upgrade. Anyone know if an LS motor will mount right up to the 454 stand?
Rich Andrews
Re: 454? On DB hull
Post by Rich Andrews » Thu Mar 17, 2016 4:25 pm
U should be fine, I run a fully equipped 13.6 DB w a SBC and it does just fine at what I ask it to do. Just make sure you have a good valve train,good cam, and the right gearbox to prop ratio. Get the card on your cam and ask a pro
loudmouse
Re: 454? On DB hull
Post by loudmouse » Thu Mar 17, 2016 4:52 pm
There is mounts for the LS that adapt it to BBC engine stands. Keep an eye on the oil pressure and tune and the 454 will live.
Joe
Re: 454? On DB hull
Post by Joe » Thu Mar 17, 2016 5:36 pm
Like loud mouse said,there are mounts to put a ls motor on a BBC/sbc engine stand with out any modification. Depending on what year 454 your using it may save you some money. The newer gen 6 is a great plat form. The vortec heads are great heads for airboat and it's a factory roller motor. It's what I used. Crow hater did a real nice Wright up on here about a budget 496 build that make good power in the correct rpm range. Look it up even if you don't want to stroke it. But if you do decide to stoke the motor whites performance has a good deal on a nice rotating assembly.
And thanks john c for posting that pic!!
LoxStroker383
Re: 454? On DB hull
Post by LoxStroker383 » Tue Apr 05, 2016 3:58 pm
I run a 14x8 DB with high sides 383 stroker and a 3 blade NGR with 2.38 ox box. Ran dry with 4 people and a cooler last weekend.
14x8 Diamondback, 383 Stroker, 2.38 OxBox, 80" 3 Blade NGR
emmitt Kelly
Re: 454? On DB hull
Post by emmitt Kelly » Tue Apr 05, 2016 7:57 pm
this setup has worked for me since 1999...you do need 3 blades....14'7" x 7.5'
Iron heads also
1999 Diamondback 502 marine Power
Sensenich S 2.55 stinger
Covington, Ga.
glades cat
Re: 454? On DB hull
Post by glades cat » Tue Apr 05, 2016 8:08 pm
That 454 will be just fine on that DB. Supply with good valve train components, keep the tuning modest and it will live just fine.
