Griffin Radiator - Junk
SEMPERFI77
Re: Griffin Radiator - Junk
Post by SEMPERFI77 » Tue Aug 16, 2016 9:39 pm
ALREADY BEEN SAID BUT I WENT THROUGH 2 GRIFFINS, CHANGE THE WAY I MOUNTED IT AND STOP CRACKING THEM. ENGINE STAND TORQUE IS WHAT CAUSED MINE. THAT AND PUT AN ALUMINUM SCREEN ON THE PROP. SIDE. :old_glory:
Post by SWAMPHUNTER45 » Wed Aug 17, 2016 7:04 am
I can tell you this, my problem was a poor quality radiator not it's mounting. The thing that got me really pissed was not so much the fact that after 2 years the epoxy glue failed. I had ordered a custom radiator from Griffin, worked with their staff telling them it was going on a airboat application, then when I called to discuss my problems the chick in customer service says "you need an airboat radiator" those epoxy ones won't hold up! WTF
It's over, the radiator is replaced with another brand.
90chevy396
Post by 90chevy396 » Thu Aug 18, 2016 12:13 pm
here is how mine is mounted so there is no flex issues I made hook mounts that wrap around the top and bottom of the radiator and the uppers are mounted with a bolt so they can be removed and there is rubber floor mat from home depot installed between the radiator and the mounts to allow the flex and for less than $150 my engine doesn't get over 140 degrees unless I idle too long. but no matter whast as long as the boat reved up she stays at 125 to 140
90chevy396
Post by 90chevy396 » Thu Aug 18, 2016 12:19 pm
here is what's on the business card
specialty cooling products
4405 londontown rd
772-257-1075
Richard Griffin
Post by kwanjangnihm » Thu Aug 18, 2016 12:32 pm
SWAMPHUNTER45 wrote: the chick in customer service says "you need an airboat radiator" those epoxy ones won't hold up! WTF
dont you hate when that happens!! :banghead: :violent1: :scratch:
