Cruising speed rpm?
jeepinocala1111
Cruising speed rpm?
Post by jeepinocala1111 »
I am taking a guess at this and saying 3000 is a good rpm during cruise speed.
Re: Cruising speed rpm?
Gear drive car motor boat it would be a reasonable deep water rpm.
I have seen boats cruise at 2600 and others needed 3600 just depends on boat, ratio, prop and load.
pontoon outlaw
Post by pontoon outlaw »
:salute: ole Lightning only needs 2200 to cruise around :lol: with the wind at her back of course :stirpot:
jeepinocala1111
Ok so I found a simple issue the prop blades were pitched wrong onemail was at just past three, one was at three, and the last one was just at the low side of three. I set all of them just past three maybe 3.5 this should be good. If there is one thing I have learned all my life it is clearly being able to tell when hp is being used correctly. I have a three Blade r series what's the difference between this and a ngr Blade? I am at 3.5 feeling like I need more Blade possibly. Is it possible these blades can turn in the hub after being torqued down?
R blades are probably the best all around blade. The NGR has winglets is a little quieter maybe slight better low end but not to much more than that. They are very close in design if you need more your talking about length or additional blade.
I would get with PTR34, Outlaw or Darrin and see what they think.
Post by kwanjangnihm »
jeep I may have missed it, did you buy a CM boat?
let me know so I can take you off the christmas card list if you did!! :stirpot: :toothy7:
BluByU2
Post by BluByU2 »
I cruise at, or about 2300 rpm with no headwind. Three blade 78" Whispertip, and a 1.53 Rotator.
jeepinocala1111
kwanjangnihm wrote:jeep I may have missed it, did you but a CM boat?
Yes trust me it takes some getting used to. Much better for going anywhere but a barge compared to my old boat. I do regret letting my old boat go but this will be great for hunting it's much more stable. You know how it is buying a used boat you first have to fix the things that are turn key to someone else. I will post the specks but there is no way it will cruise under 3000 rpm from what I will guess. Anyway I can tell someone real quick the difference between a car engine boat and an ac.
Post by Deano »
BluByU2 wrote:I cruise at, or about 2300 rpm with no headwind. Three blade 78" Whispertip, and a 1.53 Rotator.
And there is a big torque x small gear example I eluded to earlier. :salute:
jeepinocala1111
I have a 2.55 reduction.
Yep Deano that ole 514 roller Cadillac on a 1:53 vs a sbc on a 2.55 is a great example of torque vs horsepower.
scottyroll
Post by scottyroll »
I cruise @ 2800-3000 with my 2.37 box. It might go down once I get running on all 8 cylinders again and I can throw some pitch in the prop!
:Scotty-Roll:
FLAwless
Waterthunder
Post by Waterthunder »
Of topic but all three DDs cruise between 1,200 and 1,500RPM's. They just sip the fuel I love it!
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Post by One Eyed Gator »
Jeep, your comment was basically all three blades were at different position based on the marks, Did you check with a digital level or straight on the transom or cage.
I use 1 mark as a reference then set the other to that with a digital level, stick or wire to transom or cage. When mine are tracking correctly they are never at the same pitch mark.
jeepinocala1111
One Eyed Gator wrote:Jeep, your comment was basically all three blades were at different position based on the marks, Did you check with a digital level or straight on the transom or cage.
I will check again today but I ran a real quick check on Saturday after I went riding I could tell for dam sure it needed more pitch.
Des Moines Boater
Post by Des Moines Boater »
I cruise at 3000 RPMs too. I just cruise around 30 mph GPS with the prop pitched on the 2 mark and I cruise 40 mph with the pitch set on the 3 mark. I have no idea what I should set the prop at but I know I have plenty of engine for more pitch. I have a 2.7 to one gear box, so, at 3000 RPMs I'm only turning the prop around 1100 rpms. I don't know if there is a right answer.
13' 6 Lazer, 383 SBC 425 hp, 2.7 Ballistic, 3 blade 80 NGR
PAINKILLER
Post by PAINKILLER »
I cruised at 2200 with a 2.1 no tuning to the hull had i put more pitch in the prop might have been lower
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
CarMotorBarge
Post by CarMotorBarge »
You all need to watch out. Those EcoTurds and LS DD boats are going to out perform those high torque and low gear ratios boats and get better fuel mileage. :stirpot:
So I got 4 MPG this past weekend with my inefficient low torque motor and 2.68 ratio on a 5 seat barge. Rode to BS Hill, Bears Bluff, Jolly Gator, Loughmanns, and Lake Harney. Also ran the hill a little. Post up what fuel mileage numbers you are getting with those high torque motors and low gear ratio. The fuel mileage gives a better picture about efficiency.
caddy
Post by caddy »
1300-1500 rpm DD caddy. Sprea dbore holley great mileage. :stirpot: :stirpot: :lol:
jimbo_jwc
Post by jimbo_jwc »
Waterthunder wrote:Of topic but all three DDs cruise between 1,200 and 1,500RPM's. They just sip the fuel I love it!
Kinda like cruising at 1200 boat loaded and to me WOT is 3000 then the Prop gets louder than mufflers .
OneBFC
Post by OneBFC »
SWAMPHUNTER45 wrote:Yep Deano that ole 514 roller Cadillac on a 1:53 vs a sbc on a 2.55 is a great example of torque vs horsepower.
Realize that both caddy and SBC setups have to make the same Horsepower to move the boat the same speed (let's ignore weight for the moment).
So it isn't really Torque vs hp.
-Russ
jeepinocala1111
A great way to think of torque and hp is to look at a mustang and a diesel f250 Mustang has around 420hp and about the same torque f250 has 440hp with 860 torque. But the mustang with kick it ass right up till you have to pull something.
OneBFC
Post by OneBFC »
A great way to think of torque and hp is to look at a mustang and a diesel f250 Mustang has around 420hp and about the sametorque f250 has 440hp with 860 torque. But the mustang with kick it ass right up till you have to pull something.
Actually that is exactly how people get confused. They get hung up on a large torque number.
When it comes to turning a propeller, both the Mustang and the F250 you use as examples will turn nearly exactly the same propeller and produce nearly the exactly the same thrust. The ONLY differences between them is 20hp which will work out to about 60 to 80 lbs of thrust difference as well as the fact that the Mustang engine will be turning 2 to 3 times more RPM.
A 10000 lb-ft torque engine that makes 100 hp will not move your boat very well.
-Russ
papasmurf
Post by papasmurf »
running apache hull with 400 sbc DD and cruising at 1800 rpms with no wind
Bdriller
Post by Bdriller »
well heres one yall can fuss about I have two choices on a motor, number 1 is 383 cui. 500hp 480 torque #2 choice is 400 cui. 480hp 560 torque now which one do you think is the right choice with 2.7 gear? I realise a sounder decision could be made if both dyno sheets were made available but I cant see where this is not a no brainer.
