Adjusting a 6 blade wrap drive
bobby1975
Post by bobby1975 » Mon Aug 22, 2016 12:53 pm
Ok sorry but I got a dumb question can you adjust a 6 blade wrap drive with 3 blade at a different pitch???
14ft Apache 350 dd with a 68" 6 blade wrap drive
odcjohn
Re: Adjusting a 6 blade wrap drive
Post by odcjohn » Mon Aug 22, 2016 2:01 pm
YES you can i've run my razor x at 3 Deg staggered
bobby1975
Post by bobby1975 » Mon Aug 22, 2016 2:11 pm
Thanks
HAMMERHEAD
Post by HAMMERHEAD » Mon Aug 22, 2016 4:28 pm
Yes you can. I would use it more for fine tuning that last little bit and not have a wide spread between the blades. If you have the correct number of blades on your motor you should be able to run the prop with the optimum pitch in it. That means if the blade performs best pitched at 10 degrees then all the blades should be set as close to 10 as the motor can stand. Example you don't want 3 at 12 degrees and three at 8 degrees. Another example you don't want a 6 blade that you have to run on 6 degrees you would be better with 5 blades set at 10 degrees
bobby1975
Post by bobby1975 » Mon Aug 22, 2016 8:41 pm
Ok thanks that makes sense I might have to buy new plates and go to a 5 blade
john1edwards
Post by john1edwards » Tue Aug 23, 2016 7:54 am
just run 4 blades in your six blade hub. for a 350 direct drive all you need is 4 blades
Just an Orange Engine, Nothing Fancy . Proud to be an American
bobby1975
Post by bobby1975 » Tue Aug 23, 2016 9:29 am
What do I do just remove two blades and leave the holders in there to take up the space?? Or do they make something to go in there?
john1edwards
Post by john1edwards » Tue Aug 23, 2016 6:57 pm
i always took the holders out.
odcjohn
Post by odcjohn » Wed Aug 24, 2016 12:20 pm
2nd ^^^^^^ take out
bobby1975
Post by bobby1975 » Wed Aug 24, 2016 7:37 pm
Any idea what to pitch the prop that when I pulled two blades ?
mojoe
Post by mojoe » Wed Aug 24, 2016 8:33 pm
There are a lot of 350's and a lot of opinions about pitch vs rpm. A reasonable starting point is 10°.
I ran a 350 DD with a 68 5 blade for years set about 7°. One blade less and a couple degrees is a decent guess knowing nothing about the motor. I preferred more pitch and WOT about 2800. A lot of guys target 3000. Just play with it till you find what it likes best.
Mark 7:9
john1edwards
Post by john1edwards » Thu Aug 25, 2016 8:10 am
mojoe wrote:There are a lot of 350's and a lot of opinions about pitch vs rpm. A reasonable starting point is 10°.
The majic number for my was 2650, but I agree warp does better at less than 3000.
john1edwards
Post by john1edwards » Thu Aug 25, 2016 8:11 am
