Running a 16 foot Trailboss with a 383 stroker has 2.3 and a 3 blade whirlwind . I make about 450 horses and I'm looking to do a carb upgrade..
What size and type of carb do I use? Please help...
What carb to use on a Chevy 383 stroker
- Southern Airboat Member
- Site Supporter - I
Re: What carb to use on a Chevy 383 stroker
https://www.holley.com/products/fuel_sy ... 0-80801HBX
or
https://www.holley.com/products/fuel_sy ... rburetors/ Fill in the blanks either way Holley ultra is the best carb I have used yet.
or
I run a Holley double pumper 750. I run a air to fuel gauge. Which let me rejet for the best performance for me. I run a little rich. But running lean isn't good. I run an 82" 3 blade R set past the 3 mark and turn 5400 at WOT. And my timing is set for 32 wot too.
Treasurer FAA
Svcliche@yahoo.com
Treasurer FAA
Svcliche@yahoo.com
- Site Supporter - IV
whatever you buy if it's off the shelf chances are its not 100% tuned right. Prob more like less than half right
- Waterthunder
- Site Supporter - VIII
- Contact:
A great combo for you is buy the Holley 700CFM DP PN# 41778C they come with a 50cc pump on the 2nd dairies which you need one but on the primaries. So you then move the 50cc pump to the primaries. Swamping accelerator pumps and change the primary discharge nozzle to a larger .035 or .037 tube style. Be sure to also swap out the pump cams. This combo works on 99% of all small blocks sometimes you need to change a power valve to get it perfect but this combo works really well. Done this in all honesty a 100 times and the customer always says their throttle response is drastically improved.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
321-508-5316
What Dave said. That's what I have done. Except mines a 750. I have rejeted too. The response is great. And I go just about anywhere I want until I get stuck.hehe
Treasurer FAA
Svcliche@yahoo.com
Treasurer FAA
Svcliche@yahoo.com
What size jets did you end up using?
Your jetting can vary up or down considerably by numerous factors.I don't know why nobodys pointing you in this direction but I sure will.. get a good carb tuner who knows his shit you wont regret spending the money.
I run a Holley 750 double pump. Works well.
- Contact:
I run 750 AED carbs on almost all my 383 engines and have never had a problem.
Sensenich, Ox Drive gear box dealer 386-279-3712
