Buying vs build sbc
JAMES
Buying vs build sbc
Postby JAMES » Thu Nov 24, 2016 5:47 pm
At this point i have my hull rig ect ready for box prop and power plant i am stay steady with business concrete construction is good right now ! I talked with my machine shop who has done my machibe work for over 18 yrs now his price is fair i also had him price just doing the build it was fair but i think im gonna get a few more quotes first. im looking for a new 383 roller cam alum head motor around 4-425 hp at a decent rpm i have a budget of 5000.00 i priced it out as said not much cheaper to buid it my self which my last 3 ive built just too busy and really not saving much for doing so . Suggestions ??
Re: Buying vs build sbc
Postby SWAMPHUNTER45 » Thu Nov 24, 2016 6:37 pm
I prefer to pick every component and specification rather than have someone hand me what they think I want.
Not every component is equal especially with aluminum heads and pistons!
JAMES
Postby JAMES » Thu Nov 24, 2016 7:25 pm
SWAMPHUNTER45 wrote:I prefer to pick every component and specification rather than have someone hand me what they think I want.
No matter which way I went I wouldn't mind a builder just hand me something I've been doing this way too long I know it works so obviously I would tell them what I want I'm really considering a mas383 just really don't want to spend that much money I'll call Keith tomorrow see what I can do
Postby SWAMPHUNTER45 » Thu Nov 24, 2016 9:37 pm
Probably around $6,500 on the MAS but a really good engine.
Last I checked they used Edelbrock heads, forged internals and had a 2 year warranty!
To me that's the way to go, be little over budget up front but well worth it James
406 JAMIE
Postby 406 JAMIE » Fri Nov 25, 2016 8:44 am
hello james if u like plz call Rank High Performance its my lil brothers shop we do airboat motors all the time.Nos refills race fuel driveshafts and speed shop wright next door same building and custom machine work. Tell them i/jamie mcdonald sent u he will answer the phone. Hope this helps hes located off industrial rd.wright off wickham and ellis rd. :rebel:
jeepinocala1111
Postby jeepinocala1111 » Fri Nov 25, 2016 11:16 am
5 grand is not getting you a dependable 425hp engine built right. What you'll get are shortcuts to produce the power to make you happy. MAS a great engine if you spend 11 grand. Just being honest.
JAMES
Postby JAMES » Fri Nov 25, 2016 11:24 am
jeepinocala1111 wrote:5 grand is not getting you a dependable 425hp engine built right. What you'll get are shortcuts to produce the power to make you happy. MAS a great engine if you spend 11 grand. Just being honest.
I've had seven quotes they've all been in that ballpark Other than mas which is 6500 do remember these motors are not dressed out there long blocks . If you're paying 11,000 for a 383 some 1 stuck it up your azz
jeepinocala1111
Postby jeepinocala1111 » Fri Nov 25, 2016 11:36 am
GTO airboats
383CI /450HP GTO/MAS SMALL BLOCK
383-450The most versatile engine at a great competitive price. It all starts with a 383 cubic inch block and the Edelbrock E-Tec cylinder heads, offering an incredible 480 ft/lbs of torque @ 4400 RPM with a smooth linear delivery. The combination of a 4.000" bore and 3.750" stroke steel crank and hydraulic camshaft produces 462 HP @ 5500 RPM.
Specifications
Horsepower: 450 @ 5200 RPM
Torque: 480 ft/lbs @ 4400 RPM
Compression Ratio: 10:1
Block: Cast Iron 4-Bolt Main with 1-piece rear main seal
Crankshaft: Forged 4340 Steel (externally balanced)
Connecting Rods: 5.7 I Beam with ARP Bolts
Pistons: Forged Aluminum
Camshaft: Hydraulic
Rockers: 1.5:1
Cylinder Heads: Aluminum Edelbrock E-Tec 62cc chamber
Intake: Edelbrock RPM Airgap
Carburetor: QuickFuel 750cfm Mechanical Secondary
Ignition: HEI
Additional Parts Included:
8" balancer
5-quart oil pan with windage tray
Aluminum valve covers with oil cap (provisions for PCV breather)
Painted Steel front timing cover
Engine oil dipstick and tube (passenger side)
Brass freeze plugs
Spark Plugs
PRICE: $6,549.00
That is a good price I am very surprised.
bkmail
Postby bkmail » Fri Nov 25, 2016 11:41 am
Def can get a great performance motor built for $6500 ball park.
We have one coming from MAS right now. 383 stroker. We cant build one locally WITH a 2 year warranty for that. Great deal on a purpose built airboat motor.
Bk Marine Services in Palmer, Ak
Bk
502 BBC on a 18' Alumitech w/4 blade master blasters, Skip built
540 mountain motor
Postby 540 mountain motor » Sat Nov 26, 2016 9:25 pm
bkmail wrote:Def can get a great performance motor built for $6500 ball park.
Bk
This is correct. MY shop has purchased multiple 383 and 427 engine packages from MAS. Including engine parts to upgrade customer existing engines. We have built several racing LS engines this year using MAS rec parts wth great results..
18x8 GTO Saltwater Series, 540 MAS/PFI, 82 SW with Stinger 2.55, "540 RAT-N-A-CAGE"
Users browsing this forum: Bing [Bot] and 1 guest
