Honeycomb Radiator Protector
BigDaddyT
Postby BigDaddyT » Wed Jan 18, 2017 7:12 pm
I just purchased a new radiator and wanted something that would protect it from getting damaged as best I can. I remember seeing dirt track guys running these honeycomb radiator protectors and they seem to work without restricting airflow too much. Anyone ever use them or have opinions on them? They only run 30 bucks so they aren't real expensive.
13' 6" Combee Hull with 472 Caddy. Whirlwind Whispertip 72" Prop
Krahammer
Re: Honeycomb Radiator Protector
Postby Krahammer » Wed Jan 18, 2017 10:08 pm
I have not used that. I use aluminum gutter guards from Home Depot. They come in 5 or 6 inch width and cut to length. There is a ridge down one side that holds it off the radiator. I connect the pieces with tie-wraps and bolt the assembly to the radiator frame. Works really well and does not affect cooling.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 6:23 am
Krahammer wrote:I have not used that. I use aluminum gutter guards from Home Depot. They come in 5 or 6 inch width and cut to length. There is a ridge down one side that holds it off the radiator. I connect the pieces with tie-wraps and bolt the assembly to the radiator frame. Works really well and does not affect cooling.
Thanks Krahammer. I'll look into that.
jeepinocala1111
Postby jeepinocala1111 » Thu Jan 19, 2017 6:32 am
While on a ride I saw a guy's radiator he had screen like on a window with the aluminum frame he said it works great that when it gets clogged you can simply tap it with your hand and everything falls off.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 7:47 am
jeepinocala1111 wrote:While on a ride I saw a guy's radiator he had screen like on a window with the aluminum frame he said it works great that when it gets clogged you can simply tap it with your hand and everything falls off.
Hmmm, that's interesting Jeep. I would have thought that the possibility of that screen ripping, or tearing would be high and the only thing keeping it in it's frame is a little piece of rubber tubing. I guess you could mount it so that the side with the rubber tubing is pressed up against the radiator to eliminate or minimize it's ability to pull out.
jeepinocala1111
Postby jeepinocala1111 » Thu Jan 19, 2017 9:02 am
They sell metal screen and I believe he made his own frame.
Krahammer
Postby Krahammer » Thu Jan 19, 2017 9:32 am
Here is a photo of mine, from gutter guard material.
Here is picture of mine from gutter guard material.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 10:23 am
jeepinocala1111 wrote:They sell metal screen and I believe he made his own frame.
Aahh. I was thinking only of the fiberglass kind. Didn't remember the metal type of screen.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 10:25 am
Krahammer wrote:Here is a photo of mine, from gutter guard material.
That looks like that would fit the bill. Thanks for the photo Krahammer.
digginfool
Postby digginfool » Thu Jan 19, 2017 11:20 am
Here's what's on my DB. I highly recommend having something fairly heavy duty. A friend of mine almost lost an engine because the air cleaner bolt snapped off and went through the prop. The prop then faithfully handed it off to the radiator with great force, promptly blowing a hole clear through. He didn't have any type of screen like mine; bare radiator. Luckily, he shut it off before any damage but could have been bad.
getchasumairboats
Postby getchasumairboats » Thu Jan 19, 2017 11:59 am
I have stainless expanded behind the radiator and house screen up front never had a problem
http://WWW.********* where the weak are killed and eaten !!!!!
getchasumairboats
I know of others with stainless house screen in the front aswell and works great
bkmail
Postby bkmail » Thu Jan 19, 2017 12:23 pm
I have built them out of aluminum and steel expanded metal with a 1" wide flatbar aground the exterior to fasten it to the radiator.
Bk
502 BBC on a 18' Alumitech w/4 blade master blasters, Skip built
glades cat
Postby glades cat » Thu Jan 19, 2017 2:02 pm
Good product. Cut to size. Use the fastener kit to attach to radiator or frame it and mount it. If mounting directly against radiator, use rubber dampeners in between to isolate vibrations and prevent abrasion damage.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 6:01 pm
digginfool wrote:Here's what's on my DB. I highly recommend having something fairly heavy duty. A friend of mine almost lost an engine because the air cleaner bolt snapped off and went through the prop. The prop then faithfully handed it off to the radiator with great force, promptly blowing a hole clear through. He didn't have any type of screen like mine; bare radiator. Luckily, he shut it off before any damage but could have been bad.
That's the kind of stuff i want to protect my new radiator from. That looks really heavy duty. Good design and doesn't look like it will block airflow any. Thanks for the photo Diggin'.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 6:08 pm
getchasumairboats wrote:I have stainless expanded behind the radiator and house screen up front never had a problem
I have seen so many airboats with no protection that I was beginning to think that the reason was because it restricted airflow too much. Glad to see that you and others do have some layer of protection on the radiators. I guess it all boils down to personal choice on the design but I like simple. Thanks for the reply getchasum.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 6:10 pm
bkmail wrote:I have built them out of aluminum and steel expanded metal with a 1" wide flatbar aground the exterior to fasten it to the radiator.
Bk
Bkmail, that seems to be the prevailing design from what I can see. Maybe a few changes depending on the mounting options needed but very functional and simple. Thanks for the reply.
BigDaddyT
Postby BigDaddyT » Thu Jan 19, 2017 6:12 pm
glades cat wrote:Good product. Cut to size. Use the fastener kit to attach to radiator or frame it and mount it. If mounting directly against radiator, use rubber dampeners in between to isolate vibrations and prevent abrasion damage.
Thanks Gladescat. Don't know much about it's longevity but it seems to do the job for the dirt track people. Glad to hear that it works on airboats also.
Duff0113
Postby Duff0113 » Tue Jan 24, 2017 9:25 am
You all just reminded me that I need to do this very same thing haha thanks guys :salute:
PeaRiverOpossum
Postby PeaRiverOpossum » Wed Feb 15, 2017 11:34 am
Anything you need here. Digginfool has a good point. Aluminum "screen" will NOT stop a bolt slung by the prop. I saw the same thing happen with a starter bolt.
http://www.mcnichols.com/
Sent from my SM-N920V using Tapatalk
Krahammer
Postby Krahammer » Wed Feb 15, 2017 9:54 pm
Mine is intended to protect against brush and sticks puncturing the radiator when running willows or sticks. It is not intended to be bullet proof or to stop metal projectiles after bolt failure.
Users browsing this forum: Bing [Bot] and 3 guests
