Need more power, not sure which route to take
CarMotorBarge
Re: Need more power, not sure which route to take
Postby CarMotorBarge » Mon Jan 30, 2017 7:00 am
I don't know for sure if the 90mm throttle body will work on the truck intake. You need to ask the manufacturer. Most everybody is using the car intakes.
Why don't you want a high lift cam? There are a ton of high lift cams in the marsh doing just fine. WT, MAST, TKE, etc. are all using high lift cams on their 550 HSP and up motors.
Also why not spin the motor up to 5500 RPMs? There is a substantial amount of additional thrust made from 5000 to 5500. If you need more thrust, this is one of the easiest ways to get it. I am not saying you need to make lots of torque above 5000, but I am saying you need the HSP to carry to at least 5500 to 5600. Ultimately HSP is what determines how much prop you spin. Not torque.
419 CI Horsepower Barn LS3 with 2.68 Rotator soft drive swinging 4 blade 83.5" R
Member of Seminole Airboat Club
Moritz
Postby Moritz » Fri Feb 03, 2017 8:27 pm
I have a 600hp big block with gear box for sale
RedfireSVT
Postby RedfireSVT » Sat Feb 04, 2017 8:02 pm
Ok, the plan is to put a cam in there (waiting on some cam specs) and going to pull the heads and have them ported along with new lifters, pushrods and anything else needed for the cam upgrade. Going to get rid of the VVT. Then a new tune and see what that does for the power. At least I have a plan so I can get started on this thing, I want to be ready by spring.
16x8' 2014 Longhorn Custom
6.0L LS Motor
80" 3 Blade Whispertip
Love it!
CarMotorBarge
Postby CarMotorBarge » Sun Feb 05, 2017 7:42 am
Sounds like a plan. Keep us posted. You also might want to consider an AFM delete kit. Not sure if you have done this already, but you don't want the AFM on an airboat. Here is a link to an AFM delete kit:
https://www.texas-speed.com/p-717-dod-afm-delete-kit-for-536062-engines.aspx
This kit has a lot of the parts you are going to need such as lifters, head gaskets, etc.
RedfireSVT
Postby RedfireSVT » Sun Feb 05, 2017 6:02 pm
I got the cage off today and I'll try and get the heads off next weekend. Not much but it's a start!
6.0L LS Motor
Love it!
CarMotorBarge
Postby CarMotorBarge » Mon Feb 06, 2017 8:50 pm
Looks like you are having fun. 8)
junglecat
Postby junglecat » Thu Feb 09, 2017 11:54 am
Don't go too high of a lift with your cam . I have an extremely high lift , and you lose the ability of slowly idling up on fish / frogs etc. my boat actually rocks side to side . Trying to gig Talapia , they will feel it and leave before they are in range.
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
RedfireSVT
Postby RedfireSVT » Thu Feb 09, 2017 5:01 pm
junglecat wrote:Don't go too high of a lift with your cam . I have an extremely high lift , and you lose the ability of slowly idling up on fish / frogs etc. my boat actually rocks side to side . Trying to gig Talapia , they will feel it and leave before they are in range.
What would you recommend on the lift?
6.0L LS Motor
Love it!
junglecat
Postby junglecat » Thu Feb 09, 2017 11:41 pm
If I had a LS motor I'd make a call to WaterThunder. He would know a lot more than me.
2.68 Ox Box
82" 3 blade R
RedfireSVT
Postby RedfireSVT » Fri Feb 10, 2017 11:11 pm
I'm going to try Mast Motorsports for a cam.
6.0L LS Motor
Love it!
Users browsing this forum: digginfool and 4 guests
