Off season prep
Basin_Runner355
Off season prep
Post by Basin_Runner355 »
Well hunting season is over won't. Be using the boat that much till September what are some tips to store it and when come time to use it won't have any problems or minimum. Such as type of fuel additive Ima plan on keeping tank full so moisture don't build up in the tank but also don't want 45 gallons of gas to go to waste
14ft diamond back mild zz4 355sbc pushin 450 hp 450 TQ 2:1 belt drive reduction with a 3 blade sensenich 78Jw series
terrible ted
Re: Off season prep
Post by terrible ted »
Still going hear until turkey is over in May. After that i plan on rewire and rearranging the seats. Avgas can be stored all by it self for a year.
I would take it out for some fishing and riding every few months just to run it.
terrible ted
Re: Off season prep
Auto fuel can stay a few months but after that it will start degrading. I have a bay boat run it every few months to keep it right.
Basin_Runner355
Re: Off season prep
Its hard to go burn 45 gallons at a time and I wanna keep it full so moisture don't build up
Basin_Runner355
Re: Off season prep
It's not hard to burn that much gas just don't want to
terrible ted
Re: Off season prep
the gas will go bad nothing you can do about regular or the crappy e gas. So put a water separator on the fuel system. or run it on a week end every 2 months. go fishing
Rick McC.
Re: Off season prep
Post by Rick McC. »
I've been using a product called "PRI-G" (PRI-D is for diesel) for many years now. It's available at marinas, and many boat sales places.
I add it to all the fuel I use in my boats, motorcycle, and small engines.
I also use only ethanol free gas (since it became available) in everything but our autos, but PRI-G does keep ethanol from setting out of fuel, in addition to stabilizing the gas, cleaning and keeping carbon from building up, and keeping carbs and fuel injectors clean. It also does other stuff as well, but I can't remember it all.
True story:
Remember when we first started getting ethanol in our gas down here, but we didn't know it; because the stores had six months to get the signs up?
Several of my neighbors started having trouble with their boats fuel systems, engine components, and other stuff. It turned out that the ethanol they didn't know was in their gas was breaking down fuel lines, outboard engine components, etc.
My boat (15 years old now) had no problems at all, and is still running fine; because I was (my Daddy always said it was better to be lucky than good) using PRI-G.
It costs more per bottle than the more commonly used products, but is actually cheaper to use; as one ounce treats 16 gallons of gas.
I can let my boat sit for six months or more over the winter (200 HP Yamaha Saltwater Series outboard) and it'll start right up and run fine on the gas that's in the tank from the year before. Same with the little kicker for the jon boat, my chain saw, mowers, etc.
The airboat does fine, too, though it doesn't sit as long.
Rick
http://guntipsandtalk.com
Lwells
Re: Off season prep
Post by Lwells »
Don't run regular gas in anything now for it is trash, use midrange or above or recreational fuel and the tank should be full if it is going to set for a while . Av gas, unless they make it different now can set for ever and still be fine. I've started airplanes that have set 14 years or more and flown them till I had to refill and they ran fine on the old gas.
Basin_Runner355
Re: Off season prep
I run 93 octane no where in ma area sells non ethanol gas
Rick McC.
Re: Off season prep
Post by Rick McC. »
I run 90 octane ethanol free.
Rick
terrible ted
Re: Off season prep
Here I have some year old none ethanol gas I pumped out of my bay boat before I got a new motor. The fuel wont burn in the mower - or should I say the mower wont run on it. Its like the fuel looses it ability to burn or ignite. To use it, it will need to be mixed with new fuel just to get ride of it.
So like I say run it a little in the off season
Re: Off season prep
Post by Deano »
Basin_Runner355 wrote:I run 93 octane no where in ma area sells non ethanol gas
For what you are proposing, it would worth going out of the way a little bit to get real gas to start with. It looks like you can get some in either Loreauville or New Iberia.
Don't look to be to far, considering the grief it could save you . . .
http://pure-gas.org/index.jsp?stateprov=LA
