DD thrust
Norris
DD thrust
Post by Norris »
Hi everyone, long time no post! But I have a question that only the southern airboat folks can answer. What kind of thrust would a 500 caddy direct drive engine create?
Seems I've heard of gear box engines creating 12 to 14 hundred pounds of thrust, but never heard what a big cubic inch dd might do.
Thanks Norris
Rick McC.
Re: DD thrust
Post by Rick McC. »
Norris wrote:Hi everyone, long time no post! But I have a question that only the southern airboat folks can answer. What kind of thrust would a 500 caddy direct drive engine create?
Thanks Norris
:shock: :scratch:
Rick
http://guntipsandtalk.com
Re: DD thrust
What are you looking to accomplish?
I ran one of the stronger DD Cadillac engines for 2 years on a bigger boat, it was spinning a 76 NGQ pitched on 3 mark.
You can figure a stock take out 500 Cadillac should spin a 74 Q pitched around 1.5 to 1.75 so use that as a guide and call Sensenich and see if they can provide thrust data off my numbers.
WhirlWind Propellers
Re: DD thrust
Post by WhirlWind Propellers »
The real question is what HP is your Caddy making at 3000 RPM. This is what the propeller (if correctly sized) will make Thrust out of for your boat. The magic is in the HP your motor makes at your max RPM, which is 3000 for a direct-drive set-up.
If the prop is sized correctly for your engine's power output and operating RPM, you should get in the range of 3 to 4 lbs of thrust per HP at max power (3000 RPM). So let's assume your DD Caddy makes 250 HP at 3000 RPM, then your thrust will end up in the range of 750 to 1000 lbs of thrust at 3000 RPM.
Sincerely,
Patti
:proud:
Re: DD thrust
It's torque in my world <5250
Your objective for the information (intended purpose) would be paramount.
Data is subject to enormous variables but the blessing here is you can tap years of real applications and experience and calculate or form your own analysis.
jimbo_jwc
Re: DD thrust
Post by jimbo_jwc »
WhirlWind Propellers wrote:The real question is what HP is your Caddy making at 3000 RPM. This is what the propeller (if correctly sized) will make Thrust out of for your boat. The magic is in the HP your motor makes at your max RPM, which is 3000 for a direct-drive set-up.
Sincerely,
Patti
:proud:
MY dd CADDY will just spin a 74X34 wood paddle prop a little over 3000 but don't know how much hp or thrust but its a lot on 16' Rivermaster fiberglass 4 seater w/rod and frt lockers couple on board and full fuel 47mph.
Re: DD thrust
Post by Deano »
Seems I've heard of gear box engines creating 12 to 14 hundred pounds of thrust, but never heard what a big cubic inch dd might do. Thanks Norris
Hey Norris, good to see ya . . .
I can't give you a definitive answer as I haven't done any thrust testing with my junk. We probably can arrive at a reasonable quesstimate though, by comparing a few other similar scenarios that are less abstract.
First off, good sized, and healthy automotive engines with the proper gearing and prop choices are capable of, and routinely generate 2000 or so ft/lbs of thrust. Dave reports there is a proverbial wall to be overcome at around 2200 ft/lbs where the power requirement increases dramatically. This is quite obviously beyond the realm of your question, I mention this only to put your geared guesstimate more in perspective. If I'm not mistaken, I believe Russ has reported his geared Ecotec to producing around 1250-1450 ft/lbs depending on all kinds of variables (tuning, gear, props, blade count) that he has been changing over time, while fine tuning his ride. His is a story unto its own, but does fall in the same neighborhood as did your numbers.
Getting back to the question at hand: In the beginning (well almost), when Water Walker did some of the first documented thrust testing, they used an angle valve O-540, said to produce 300 hp, to record 1200 ft/lbs of thrust. That was with a 72" 3 blade Signature and as far as I know, this is where the now proverbial 4 ft/lbs per HP benchmark came from.
It has been reported that an 220 ground power generated 800 ft/lbs thrust. This calculates backwards to 3.6 ft/lbs per HP. The caveat there is that we don't know what prop was used to produce that number. Be aware that where generating thrust is concerned, after the HP produced, the type prop used is the single biggest variable. The prop efficiency can be nearly as relevant as the HP produced when posing this question.
If you were to quesstimate that 'in most cases' or 'typically' a healthy 500 would outrun a 220 ground power and that a healthy AV O-540 would out run the 500, it would be fair to deduce that the 500 were producing somewhere between 220 and 300 HP and 800 and 1200 lbs thrust. Take the means there, and you have 260 hp producing 988 ft/lbs of thrust. I would perceive this to be a reasonably accurate guesstimation based on the number of, and the associated weights of the variables involved.
Needless to say, this only goes to show that what Patti said is correct, which wasn't my intent as there was no need. I started this post yesterday before she replied, but didn't finish it till now. I just left what I already had there as it might help put things in a little more useable perspective where thrust expectations are concerned.
glades cat
Re: DD thrust
Post by glades cat »
Good one Deano.
One thing left to factor in a practical aspect is, how much power/thrust is needed to break the hull free from its terrain from a stopped position. Prop thrust tests are usually static and different hulls have their own friction peculiarities, which will allow one hull to break free easily while another is more difficult to overcome inertia.
Just thinking out loud.
OneBFC
Re: DD thrust
Post by OneBFC »
I dont know about other public test results than these:
Real Time Thrust Tests with Complete Boats - Page 4 - Southern Airboat
http://www.southernairboat.com/phpBB3/v ... 75#p409827
So, I have yet to see someone produce a measured on the boat thrust test sheet or video or even a basic forum post that shows 2000 lbs of static thrust was made.
I know Dave says on his bench test rig where he tests and tunes his engines he sees 2000+, but that is only source and its not on a boat.
Would be nice to have another thrust test done with a wider range of boats attending. However, there are so many variables that play into what a complete boat makes for thrust that it makes it really difficult to do a "fair" compairson.
Case in point, in that thread i linked to the Big block boat put down a little over 1400 lbs. Thats what I know mine does too....and I most certainly do not make 500, let alone 600hp.
So, as has been said many times over the years here, "setup is king". I believe that to be totally true.
That, and the water walker props push like mad!
-Russ
Norris
Re: DD thrust
Post by Norris »
Thanks for the replies, where it was really headed on this was thrust bearings and how much thrust they can take. This all helps.
I've heard that the big caddys sometimes tear up the thrust bearing, so wondering how much it takes to do that.
Re: DD thrust
Post by Deano »
If it's starting out healthy and according to Hoyle, it will take quite a bit. Probably the two biggest contributing factors to that wear are improper/lack of maintenance and the passage of time w/its accumulated use.
It was not uncommon to take a good, clean, non-abused take-out, put it on a boat and run it for a couple of years or more. I've seen one go closer to ten. It is not something that is high on the list of concerns if you are starting with something that's been maintained. They are not necessarily weak, like is sometimes implied when there is an issue. They produce more thrust than, but have a smaller diameter thrust surface than a BBC, so quite obviously they were not designed to set longevity records in a DD environment. That however, is no indication that it's some kind of substandard fail point.
There are a couple of inescapable facts though, first, running dry will accelerate that wear, there's simply no way around it. The other is that it can't be ignored when there is a problem. Because they make more thrust, once the wear is significant, it will quite literally eat itself alive. Hence, the proverbial "chewed and screwed" descriptor that Bondsman so astutely coined.
Thicker oil helps maintain that cushion, I do not and would not run thin oil in an old Cadillac. Straight 40w or better will help with said wear much better than 10w-anything. I have used 20w-50 in a pinch, but prefer to not fill it with that. Swamphunter promotes a successful blend that Buddy Branch concocted, but I believe that is intended for something newer than a fresh take-out. I'm sure he will be along and is more qualified than me, to comment about that.
Just so you are aware, the factory spec for crank endplay is .002-.012 with the replacement spec being .015. If it gets wider than that, it is no longer flat and will start wearing at a greatly accelerated rate. There may be more left out your way, but those cranks are getting harder to find down here. A good crank shop can weld up and then regrind one, much more affordably than replacing one at this point.
As far as what can they take, if it's done correctly, properly maintained with good oil, and not pushing a barge around dry all the time, I would expect that it would not be an issue for a long time.
Norris
Re: DD thrust
Post by Norris »
Good responses and information. Got me thinking, isn't there a gear box out there that uses a clutch? Wonder how much pressure a clutch has on the crank when depressed? That would load the crank thrust more than a direct drive prop setup.
Re: DD thrust
Post by Deano »
I believe the Ox Box was the one that had the option to run a clutch.
Now there's a thought that I hadn't really considered. Perhaps the reason the BBC motors have a larger thrust surface is because when designed, they did have a likelihood or possibility that they would end up in front of a manual transmission. This wasn't a possibility with the Cadillac the way Detroit saw things at the time. :D
While along these lines, it could be noted that a regular gearbox wouldn't be stressing the thrust bearing any more than an automatic that it was designed for. Would never be an issue at that point. That does in fact, open a couple of entirely different cans of worms though. :)
