Throttle cable ???
JAMES
Throttle cable ???
Postby JAMES » Sun Feb 19, 2017 8:37 pm
I have a heavy duty one now im sure its not gonna work its set up like telflrx steering big nutz on each end my problem is with the new engine having a high rise intake i cant mount to like before .. SHOW ME SOME PICS IDEAS not use to the big intakes Not much to bolt to on intake
Re: Throttle cable ???
Postby SWAMPHUNTER45 » Sun Feb 19, 2017 8:46 pm
There is a metal plate you can purchase that goes directly under carb base plate. The teleflex throttle cable holder will bolt to it regardless of intake height everything lines up.
Some also accommodate both Nitrous Oxide solenoids and throttle cable holder FYI
JAMES
Postby JAMES » Sun Feb 19, 2017 8:53 pm
SWAMPHUNTER45 wrote:There is a metal plate you can purchase that goes directly under carb base plate. The teleflex throttle cable holder will bolt to it regardless of intake height everything lines up.
I assume that's what I'm going to have to do because like I said the cable I have now is too big it's like A steer cable
Postby Deano » Sun Feb 19, 2017 9:02 pm
Something like this ? They have a few different flavors.
https://www.summitracing.com/parts/trd-2333
Postby SWAMPHUNTER45 » Sun Feb 19, 2017 9:22 pm
What Deano posted is an excellent way to mount a throttle cable on a high rise intake.
Al and i have made fabricated stand alone cable holders and recently discussed these as a simple remedy to fabrication of custom height components.
JAMES
Postby JAMES » Sun Feb 19, 2017 9:28 pm
I assume that I should match the gasket I have now or does it really matter can I just use one that comes with it
Postby SWAMPHUNTER45 » Sun Feb 19, 2017 9:44 pm
They typically are the standard 4150 series pattern.
If you have a local speed shop in your area stop in they may have one on the shelf and you can look it over.
Users browsing this forum: Google Adsense [Bot] and 6 guests
