Long Journey
digginfool
Long Journey
Post by digginfool »
Wow. I've been without my DB for a year now. Long story short, the problem with my engine started because of a defective coil pack. The best they can tell it was bad pretty much from day one and that's what caused the damage. To compound matters, the engine arrived at the distributor in the Baton Rouge area three days before the big floods last Spring and my engine went under water. Since they were going to tear my engine down completely, I asked if they would re-assemble with forged components if I supplied them. They agreed and even went so far as to send it to a local speed shop to do the work. Of course, this all takes time because my engine isn't the only one waiting. To compound things, once they began to check the engine out, it was found that several cylinders were out of round so off to the machine room it went for align and cylinder bores. Finally, it's my turn and the engine is going back together. The owner of the engine shop sent me these pictures last night. Can't wait for the barge to hit the water again. Been a long time without it.
digginfool
Re: Long Journey
More
digginfool
Re: Long Journey
More
digginfool
Re: Long Journey
The rest.
Re: Long Journey
Great to hear progress and upgrades are on the way!
ffjpowell
Re: Long Journey
Post by ffjpowell »
Looks great bro. Mine will be done soon and i am planning a trip down to the glades so will def get up with you, Gerard n the crew for a long weekend.
Sent from my SM-N920P using Southern Airboat mobile app powered by Tapatalk
What the mind of man can conceive and believe, the mind of man can achieve.
Live today like theirs no tommorrow.
New build on the way!!!!!! Stay tuned.
J. Powell
Rick McC.
Re: Long Journey
Post by Rick McC. »
Excellent pics!
Hope things get completed for you soon.
Rick
http://guntipsandtalk.com
CarMotorBarge
Re: Long Journey
Post by CarMotorBarge »
What damage did the defective coil pack cause?
Rich Andrews
Re: Long Journey
Post by Rich Andrews »
your keeping the same pistons?
digginfool
Re: Long Journey
CarMotorBarge wrote:What damage did the defective coil pack cause?
Because the coil pack was not firing, unburned fuel washed the cylinder walls and allowed the piston to score the walls. I discovered the issue by pure happenstance. I had an issue with header bolts snapping and pulled the header to see if the flange was warped. When I pulled the header, I saw 3 exhaust ports black with soot and one washed clean and coated with oily residue. Took pictures and sent to Marine Power. After a few weeks of back and forth looking for somebody in Florida to tear into the motor to find out what was going on, they had me remove, crate and send to their facility. It is being covered under warranty.
digginfool
Re: Long Journey
It's back! About the only outward change you will see is the head studs. All the rest of the goodies are inside. Won't be long now!
Re: Long Journey
Awesome post up a little review, my bet your gonna find a bunch more power...lol
pipedog
Re: Long Journey
Post by pipedog »
lookin GOOD!!
Palm Beach open hull 13'9" with 6.0 F.I. LS - Ox Box and a 3bld "R"
