fuel injection pump
2WHEELER
fuel injection pump
Postby 2WHEELER » Sun Mar 05, 2017 7:25 pm
I am putting a stock injected ls on my air boat what fuel pump should I use?
Re: fuel injection pump
Postby One Eyed Gator » Mon Mar 06, 2017 9:06 am
I have used the Walbro GSL392BX 255lph external pump. Seems to work well so far.
If you use a stock intake with stock regulator mounted on the intake or use corvette filter with internal regulator if your intake does not have the fuel pressure regulator. Then there is always aftermarket Fuel pressure regulators $$.
Users browsing this forum: Google Adsense [Bot] and 4 guests
