Electronic gas pedal for 5.3 ls
porker
Postby porker » Mon Mar 20, 2017 2:05 pm
Building new boat and motor I bought is a 2014 5.3 and throttle is electronic. Hoping somebody can send me a few pics of how they rigged up the gas pedal on there boat. Thank you please help
gator7272
Re: Electronic gas pedal for 5.3 ls
Postby gator7272 » Mon Mar 20, 2017 10:56 pm
I'll try to get you a pic but in the meantime, I mounted the pedal upside down under the floorboard, connected it to a traditional airboat pedal with linkage w/ heim joints at each end. Allows for better long throw so as not to be overly reactive between idle and wide open.
11.5 X 7.5 Alumitech
2.0 Ecotec LTG
2.38:1 Ballistic
3 Blade Whirlwind 2.0
CarMotorBarge
Postby CarMotorBarge » Tue Mar 21, 2017 7:35 am
porker wrote:Building new boat and motor I bought is a 2014 5.3 and throttle is electronic. Hoping somebody can send me a few pics of how they rigged up the gas pedal on there boat. Thank you please help
Which 5.3 are you doing? Does it have direct injection?
419 CI Horsepower Barn LS3 with 2.68 Rotator soft drive swinging 4 blade 83.5" R
Member of Seminole Airboat Club
br,lc,LA
Postby br,lc,LA » Tue Mar 21, 2017 10:13 am
Mine is flipped over. Used factory bolts holes to mount in it a box then the box is mounted to the under the foot deck. This way you can move it around and even mount it extended past the foot deck like mine. Plenty of walking room.
2016 American Airboat's AirRanger pushed by an Airboat Pros 2015 1.4L GM Ecotec... "Nothin' as Fine as Hearing a Turbo Whine"
