502 power VS torque
loudmouse
Re: 502 power VS torque
Post by loudmouse » Wed Feb 28, 2018 10:12 am
You build for torque and tune for hp...
WaterThunder engines will also turn more prop than most BBCs put out by most builders with 100+ less CID. There is a reason for that and its not by accident!
Built and Tuned by Me
Post by SWAMPHUNTER45 » Wed Feb 28, 2018 10:35 am
loudmouse wrote:You build for torque and tune for hp...
And he also knows that a (16ft heavy or larger) "big boat" needs big inches and has in the past recommended the BBC platform over the LS
Post by Deano » Wed Feb 28, 2018 10:55 am
OneBFC wrote:... I was just looking for an engine with HP output higher than the torque and didn't think to check it...
It aint' a thing brother; I knew that you knew. Just trying to help contain the confusion in this thread. :lol: :lol:
I'll admit to leaning toward the torque side of the debate (and possibly because that is where I started),
but I will also confirm what Jason eluded to earlier (but didn't expand on) and that is that both are relevant.
After all these years of this, I think I could sit on and argue either side of the debate.
Now for this post, I will side with Russ and the HP is king guys and offer you the example Russ didn't think of last night.
For shits and giggles, lets consider a smaller, but quite effective little engine that has, say 135 cubic inches but turns 12,000 rpms.
This little guy by virtue of design and RPM can not produce a lot of torque (comparatively speaking), since it would be decreasing after less than half throttle. Are we in agreement so far ?
Now, I'm going to run that little engine through a 5.8:1 gearbox to turn my 4 blade Super Wides 2069 pRPMS.
If that little engine was producing between 700 and 750 HP, should work reasonably well regardless of the torque, no ?
I don't have a dyno graph because all that information isn't published, afaik. The little engine I referred to here isn't fictitious, it's
the 2.2 litre Honda V6 like they recently ran at Indy for a few years. Surely that would not be perceived as a Torque Monster, but it
ought to be clear that it could turn 4 Super Wides given a 5.8 gear ratio. If I win the PowerBall this weekend, I will show you. :lol:
CarMotorBarge
Post by CarMotorBarge » Wed Feb 28, 2018 11:22 am
kwanjangnihm wrote:CMB - why don't we use your waterthunder dyno sheet (HP & TQ) & thrust numbers for this thread as an example?
Can you supply slidin gator this data so he can plot & chart so we can all see the relationship. :salute:
This engine was never put on the dyno so I don't have this info. Doesn't matter anyways. Everybody knows that Water Thunder engines are LS motors that don't produce any torque or HSP. They are just stock motors with a Water Thunder emblem thrown on them. :shock:
On a serious note, I would estimate that this motor made 560 foot lbs of torque at about 4800 RPMs and about 620 HSP at about 6200 RPMs. Again no data to back this up, but this is about what I would expect.
What is important to learn from this thread is that this engine does not make its max thrust at 4800 RPMs. I run the motor 5800 to 6200 depending on what I am trying to do with it. A little less RPM gets me better fuel mileage and a little more RPM helps me outrun A/C boats. :stirpot: :stirpot: :stirpot: :stirpot:
OneBFC
Post by OneBFC » Wed Feb 28, 2018 11:53 am
Thanks for posting the dyno for you engine ladyblackwater.
The reason your boat accelerates well at 4000 RPM is because the propeller requires considerably less HP at 4000 engine rpm than what you engine is capable of making at 4000. The amount of power you have available from your engine above what you propeller requires is felt as acceleration.
At 4000 RPM you engine is capable of making 542hp. It is NOT delivering that much power while you are running 4000 RPM otherwise it would not have sufficient power to continue reving higher when you apply more throttle. The propeller only needs a tiny fraction of you engine's maximum power output at 4000 RPM, likely in ithe neighborhood of 100 to 200hp depending on what kind of propeller your using. I say this is the likely range of required power because otherwise you would burning a very large amount of fuel to run that 4000 RPM. 100 to 200 hp is in the range of 10 to 20 gallons per hour of fuel, give or take a bit.
Every propeller configuration will require a different amount of power to turn a given RPM. The longer the propeller and the larger the number of blades as well as the amount of pitch in the blades will all impact what the required power will be to turn a given RPM.
Notice i said power here, not torque. People get confused because below 5250, more power also means more torque. Above 5250, that isn't the case. Torque can still be climbing beyond 5250 however on some builds.
If you were to try and use an engine that doesn't make enough power at lower engine RPM to overcome the required power of the propeller at the lower engine RPM, that engine will never reach the higher RPM where it may make more than enough power to turn the same prop at that higher RPM. This is why you have to match propeller and gear reduction properly.
At no point will you ever make less thrust with more power as long as your gearing and propeller choices are matched appropriately.
Your choice to run your engine below where it makes peak power is just that, a choice. If you geared it to be able to run at the RPM where you make max power you would for sure make more thrust.
The reality is, at 4000 RPM and below, almost any reasonably sized engine will produce enough power to turn most props. You would need a very low displacment engine that is designed to deliver all of it's power in a narrow range at high RPM only and combine it with a low gear ratio box of 1.7 to 2.0, etc while also trying to spin a very large diameter prop with wide blades,etc in order to get into trouble of potentially broken setup.
NO ONE is suggesting to do that in this thread. My one and only point is, it's POWER that makes THRUST. Not Torque. Make power at reliable RPM and then select gear and prop to harvest that power.
-Russ
CarMotorBarge
Post by CarMotorBarge » Wed Feb 28, 2018 12:04 pm
And throw the charts/sheets with the torque curves in the trash. They cause more confusion than good. The HSP curve tells you everything you need to know. 8)
OneBFC
Post by OneBFC » Wed Feb 28, 2018 2:10 pm
ladyblackwater wrote:OneBFC and Carmotorbarge do either of you know how much horse power is lost in the drive and how much torque is gained or lost in a drive? No one truly knows that I know of because there is no dyno for an Airboat. No matter how you look at it there is definitely a significant amount of HP lost through the gear box/belt box and prop.
Well, to determine amount of power lost via a gear box you can measure the temperature rise of the gearbox at a known load for the engine and convert that temperature to a value in watts and then subtract that from the engines known power to get the power available at the prop shaft.
Essentially you would be establishing the gear box efficiency. Typical gearbox efficiency for low reduction ratios is in the area of 5 to 10% historically.
Factor in 10% and your generally close enough for airboating.
-Russ
Post by SWAMPHUNTER45 » Wed Feb 28, 2018 3:25 pm
We use 10% as a rule as well.
First thing Russ and I agree on :drunken:
Post by Slidin Gator » Wed Feb 28, 2018 10:19 pm
OneBFC posted earlier:
Well, I will just leave this here and you guys can finish figuring out what's going on from there. This is the Version 3 pt II 502 from the above examples. I mean, you can see that you make more thrust with 545 lbs of torque than you do with 594 lbs of torque. I think it's pretty darn clear what matters?
Red = hp
Blue = Torque
Yellow = Propeller Thrust
Sir, Thank you for that thrust information, that is actually very useful and I think if you will give me a chance I can explain how useful and where I am trying to get to here. First, I agree with a majority of what you have said and the information posted, as much as I agree with what everyone else has said. I will show where I disagree and why too. My goal is to show that there actually is a set of formulas that can be used to size a variety of boats, perhaps not to the nat’s a**, but enough to provide some baseline sizing figures (for instance, thrust => 2x boat weight and HP=> 4x boat weight). The question “I have motor A and boat B, how to I use this stuff” question comes up all the time on this forum and I hope to compile some spreadsheets that everyone can buy into and understand. I figured that this would be a useful capability for this forum that would save everyone a lot of time so everyone can spend less time arguing on the board and more time arguing in the woods.
I also figured Nola’s initial concept of a 502 on a 21 foot boat was a great example to investigate because making a boat this big run dry with limited power (I did say power) is a perfect example of a point design. Also, running dry is an example of static thrust, which is simpler to model with math. Prop’s running with forward velocity is a much more complex analysis.
As originally defined, this boat will never run the glades grass at 45 mph, then off to the levee, up and over, then through a sticky black mud trail etc… We have already determined that the 502 is a marginal motor for the application so the setup has to be tuned to do one or the other reasonably well and the other poorly, it is not going to be a dual use machine. From my view, Nola can either accept what that boat will do and build it, or make a choice to go for what could be a sweet running boat, but with a bigger budget to match.
HP and Torque are easy to define and measure (ok, Torque is not so easy to measure directly). On the other hand, propeller performance is a very complicated issue to analyze in detail, but there are fairly simple approximations that do work well for roughly sizing the system. Fine tuning on the other hand, is where math, art and seat of the pants come into play.
If I do what I say I am going to do, the result should reasonably match everyone’s intuition and experience. Except that then this experience can be extrapolated to other applications as a means to provide some guidance for all.
So to start:
First, I’m not a dumba** here, I completely understand the main point of this argument, which is make HP not Torque. But I would rephrase the statement as make “HP to Make Torque”, which is where the gear box comes in and will be a key element of all this. In many cases it’s the only variable we can tweak.
Also, I am using 90% gear box efficiency (10% loss) for all calculations, it’s the one thing everyone seems to agree on, it’s good enough for me and I don’t want to kill the good mojo you guys managed to brew up all day!
Referencing the graph showing thrust at max HP, OneBFC posted:
I have measured the thrust my boat makes on a thrust tester. I also know how much power it makes at a given RPM while thrust testing at the same time due to the information the GM ECU provides. This allows you to determine a formula for HP to Thrust (For my boat of course) and I have applied a simplified version of that to the above graph. The actual exact thrust output is not all that important however to this discussion. What's important is the relationship of HP to Thrust. It follows HP, not TQ. Propellers need power to make thrust.
I looked into the graph and spreadsheet posted. I don’t have an issue with the formulas used to create the graph, as stated they are approximations. What is important to me is that OneBFC has run some tests, gathered data and is comfortable that these formulas reasonably match the test data. Since I’m still pushing torque, I do have to point out that the data supplied by the Ecotec (and most other) ECU’s is actually defined as “Torque Demand” values in the software, the HP figures are then course calculated by multiplying by engine speed and the 5252 factor. But no need to go there….
I do have a real issue with the presentation on the chart. The thrust figure appears to be plotted against RPM, but after reviewing the formulas I find that Thrust is plotted directly versus HP. To actually put the curve presented into practice would require a gear change at every data point, or the infamous variable pitch system, which I could use for backing out of a jam.
The formula’s used are propeller scaling formulas that define power vs. thrust for a given propeller diameter. The input variable is propeller diameter and HP and the output is thrust. The Wikipedia link in the spreadsheet did not really cover these scaling formulas directly, but I found a good link (below) that does cover it well and quickly. The RC guys actually have the best data because it is way easier to test the small power stuff. Prop formulas scale reasonably well.
http://www.heli-chair.com/aerodynamics_101.html
What is important is that we have at least one set of data of actual HP that is claimed to match up reasonably well with the estimates, cool, now we are getting somewhere. So using the same formulas, I created a new spreadsheet (attached) and a graph that might make more sense to everyone.
Please double check my work at this point and let me know if you find an issue, otherwise I do have more to come.
I tried to upload the spreadsheet as an attachment, but I see that is not an option on this forum. I understand, files with Macros is one way the hacker and spammers get in. I am attaching a PDF of the actual spreadsheet. Anyone that wants a copy can PM me with an e-mail address and I will send the spreadsheet on along.
Prop Scaling.pdf
(49.25 KiB) Downloaded 27 times
Post by Slidin Gator » Wed Feb 28, 2018 11:00 pm
OneBFC wrote:
Deano wrote:Brother Russ, I am surprised you would post this graph.
I see you got it off their website, so the bull**** is theirs, not yours, but . . . really?
Do you not see a very fundamental flaw here in this graph for this
engine that not only defies the laws of physics, but mathematics as well?
Yes Deano your right, this is a bad example. It was late and I'm human. The torque and hP can't cross at that low RPM.
So, indeed, this is a poor example.
I'm ashamed to have posted that now and I do appreicate you pointing it out. Let the record stand corrected. I edit the post to clarify the mistake.
I have to bust both of you guys on this discussion. Everyone knows that CM guys will lie and cheat when needed. But Deano, your an AV motor guy! You should get it. :violent1:
The fundamental flaw here is that the units are all screwed up, at least as far as you are used to looking at them, and I get it. On the UL260i curve, power is given in HP on the left and torque is specified in Nm on the right, with a different scaling. 1 Nm = 0.738 Ft-Lbf. Here is the re-scaled graph in the form you guys are used to seeing them.
Post by SWAMPHUNTER45 » Thu Mar 01, 2018 6:50 am
It all comes down to this!
Big inch power mated to a 2.37 or 2.55 with big wide blades.
SlideGator I commend you on the graphs very nice product
OneBFC
Post by OneBFC » Thu Mar 01, 2018 8:05 am
Thanks for noticing that slidin gator. Completely missed the units on right side.
-Russ
Post by Slidin Gator » Thu Mar 01, 2018 10:28 am
SWAMPHUNTER45 wrote:We use 10% as a rule as well.
For reference, here is a quote from Waterthunder regarding gear box efficiency:
by Waterthunder » Thu Dec 21, 2006 12:37 pm
I looked into that and wow what a can of worm's I opened. The efficiency of a gearbox can change 10% in 15 minutes alone due to heat the hotter the box get's the less efficient it becomes. I spoke to a gear reduction engineer about testing my gearbox he told me it's a complex process and they cost around 30K per test. These company test's all the gearbox's for machinery and all the auto manufactures. He knew his stuff and defiantly educated me on reduction efficiency and parasitic drag coefficients changing with heat and horsepower changes. When he was done educating me I realized there can not be a good average number for gearbox efficiency percentages
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
viewtopic.php?f=2&t=4304
So, the next time you are stuck, lay off the throttle for a few minutes, let the gear box cool down. Then try it again!
Post by Slidin Gator » Thu Mar 01, 2018 9:11 pm
Ladyblackwater,
That is too easy on a car motor boat :cheers:. Just use a power steering pump, bracket etc. that fits your particular motor. You know, more of that crap that I don't have on my boat! :stirpot:
Actually, those are not ideal pumps, they would need some tuning to pump gear lube. The flow requirement for cooling is really small, a small gear pump would work great and I would make it electric driven so you can turn it on as needed. That way you don't have another belt etc. to fail on the motor, you know you can get home without the cooler.
Go to the local hydraulic supply house and get a 1/2 gpm or less (as low flow as you can find) gear pump and 12 Volt motor assembly rated for as low of a pressure and Hp as you can find. Maybe even a trim tab pump?? Mount the pump as low as possible so the high viscosity gear lube will precharge the pump. Put the cooler anywhere above the pump but below the gear box. Make sure the gear box is vented and make sure the pump is not cavitating, otherwise it is flowing too much.
Put the electric on a thermostat so it does not turn on until the oil heats up and viscosity is in operating range.
Post by Slidin Gator » Thu Mar 01, 2018 11:33 pm
It is time to wrap this discussion up on my end for a bit. The gobblers are getting anxious and Turkey season opens Saturday morning, bright and early. It is time for me to go get my yearly schooling, by an old Osceola gobbler. That’s my kind of schooling!
I have some paying work to do and this little hobby is taking some time I won’t have for a little while. So I’m going to lay out what I have got and leave it for everyone to absorb for a while.
This next post is a long one, so if you want to quote this discussion, please use this post instead of the next so everyone can keep from wearing out the mouse scroll wheel!
Post by Slidin Gator » Thu Mar 01, 2018 11:42 pm
I am going to say that I have given some looks at the 502 Nola boat and I think Nola should hold off on pouring any money into a stock 502 rebuild. If the budget allows for a big motor, 540 and up, then that should be the plan. Otherwise, I’m a run what you got kind of guy. Personally, I would tune that Lycoming 540 motor up, put a gear box on it and throw an 84” 2 blade prop or bigger if possible. By the time you put 1000 lbs (maybe more) of cast iron big block motor, radiator, gear box etc., vs. the IO540 450 lb weight, a reasonable 502 build that makes 550 Hp at 5,350 RPM is going to make enough extra thrust to net maybe 300 lbs of extra dry ground running capacity. It’s not going to burn up the hill with a load, but reasonably empty, that is about the difference of getting your big a** brother in law to get out and walk up the hill. Take the $10-$20K that a motor build, gear and prop is going to cost and use it to buy 5,000 gallons of AV gas now. Then that boat will run for years while saving money for what this boat really needs. Then the whole kit can be sold for a premium later to offset the next build. That or sell the boat and put that motor on a smaller boat.
Either way, let’s call that part 3 for later, turkey time and all.
Here goes:
I assume no one found any major issues with the prop scaling stuff. I’m now going to try and convert you guys into being torque guys instead of Hp guys. I’m not saying less Hp is better, I saying you need to think in terms of Torque instead of Hp. Hp is useful as a basic measurement for very crude sizing. The prop curve scaling diagram shows this. But Hp figures are not very useful for truly tuning in a setup, that is where torque figures come in. I noted that the ECOTech ECU calculates torque demand as a value, it does not really give a crap about Hp. The ECU can’t use Hp to figure out the correct fuel, timing etc., it maps torque demand vs. RPM!
The problem with Hp is that it already includes RPM (HP = Torque x RPM x 5252) in the measurement unit. When you graph, try to envision or even control acceleration of the boat using Hp as the variable? There are two units of RPM in play with Hp parameters and it dilutes the true relationship. If we strip the RPM figure out of the engine performance parameter (HP vs. Torque) and graph torque directly against RPM and all the other factors, we end up with a direct measurement of acceleration and therefore thrust, at anywhere along the RPM scale. Just remember, a Torque curve plotted against RPM shows how the system will perform, jump, accelerate, cruise etc. across the whole operating range. Hp tells you what it does WOT, assuming it is tuned correctly.
If you can grasp the concepts I am putting forward in the next few posts, then you my friend understand Calculus, you just didn't know it.
As a refresher, I am starting with this curve from CMB and the prop scaling data from OneBFC:
Post by Slidin Gator » Thu Mar 01, 2018 11:43 pm
On the following chart, I took the prop scaling formulas from my previous post and did some algebra on it to calculate HP required versus a given thrust point. I then matched that math up with the Thrust vs. RPM chart that CMB posted way earlier in this thread. CMB has reviewed an earlier version of all of this and agrees that it is a reasonable match to what he thinks he has. The result is a set of numbers I have been after here, a torque and thrust curve for a specific prop set up! The best part is that this prop is a damn good example of the minimum prop that Nola is going to need to swing to push that monster. So it translates well.
Post by Slidin Gator » Thu Mar 01, 2018 11:50 pm
One item of note, to make this whole discussion match up well, I used an 81% gear box efficiency figure. In my experience, this is well within reason (I have seen plenty of 75% efficiency figures for all kinds of equipment). But if you can buy into that, this whole story is a much easier read. Just remember, gear box losses are all torque, if you are losing RPM in the gear box you have some real issues to deal with. :slap:
This chart shows my model of CMB’s prop as pitched at test, with a 2.68 ratio gear box. The torque and Hp lines are the prop steady state requirements. Note that the torque and hp curves do cross at 5252 RPM. As noted previously by others, this is just a function of the 5252 constant used to calculate Hp from Torque and RPM. I want to point out that this is nothing more than a feature of the units used and the graphs scaling, something I pointed out last night on an airplane engine curve. Otherwise, there is nothing unique about this RPM with regards to performance. If I change the torque units to bananas per finger length, this crossing point would occur at a different RPM, but nothing else changes. Forget about that anomaly, it is not an important or magic point on the RPM curve. The only real important limit is the Mach number of the prop. As this model grows beyond the CMB boat here, Mach number will be a key discussion element.
I think this model is reasonably accurate in the higher power range. But the prop scaling formulas are for a 2 blade prop, compared against OneBFC’s 3 blade prop and then applied here to a 4 blade prop. I don’t think that graph is very accurate down low, so this next graph zooms into the power range of interest. Keep in mind this is all a model of the prop, I have not added in engine parameters yet. :scratch:
Post by Slidin Gator » Fri Mar 02, 2018 12:07 am
What we are missing is an idea of what the motor performance curve really looks like. I found a good set of dyno curves for a 427 LS7 engine to use at this link:
http://www.powerperformancenews.com/tec ... sx-intake/
This curve shows side by Hp and Torque for a stock LS7 and with the addition of a Mast Superflow Intake manifold. Going back in CMB’s posts, he made the following statement about his engine:
Please note that the Red graph HP and Torque lines on this dyno chart match up with the 2 performance figures that CMB is claiming. Basically, the Stock 427 LS7 performance curves appear to be a reasonable match to CMB’s 419 engine. For the purpose of this discussion, I am going to call the red line the “CMB Torque” set up, he just did not know he was a torque guy!
The blue lines show a Mast aftermarket intake manifold upgrade. You can read all about it at the link provided. As these curves show, this motor makes more Hp (maybe 30 Hp more at 6,500 RPM). It also makes up to 10 Ft-Lbf more torque after 4,750 RPM. But look at that torque and Hp take a nose dive below 4,750 RPM! Don’t forget that the prop is set to limit max RPM at 5,350 RPM. So the hot rod intake manifold has a narrow window where it out performs. I’m going to call this the “Hp” set up
Post by Slidin Gator » Fri Mar 02, 2018 12:27 am
Now, if I have not yet sold you on the HP vs. torque thinking yet, here is CMB’s set up matched up versus these two engine configurations. This set of graphs is why I changed gear box efficiency to 81%. Doing that made the propulsion torque curve (Orange Line) cross the stock LS7 torque curve (Red) at 1,860 lbf of thrust. Otherwise it would not make sense to show the thrust limiting out with torque remaining. As I said, it makes the story easier to tell and is well within the error range here:
Zoomed in for detail:
So yes, the hot rod Mast intake does make a whole extra 10-20 lbs of thrust at top end, standing on it, stuck on the green grass. But Look at how flat the “CMB Torque” (red) curve is from 4,500 to 5,350 RPM at or above 565 Ft-Lbf. Look how torque remains above 500 Ft-lbf at 3,500 RPM where the Mast intake “HP” set up makes 380 Ft-lbf of torque. Now go back and re-read my first round of posts on matching instantaneous acceleration torque against the prop curve to get instantaneous acceleration/thrust.
Which set up do you want in your boat? If you say the “Hp” set up, you need to quit reading this thread, I can’t help you! Just go back to what you know works the best. The ”CMB Torque” set up is going to jump out of a hole, jump the river bank, and get going on dry ground MUCH better than the “HP” set up. In short, the Torque set up is more enjoyable to run.
Consider that static friction (boat not moving) is always higher than dynamic friction (boat moving). To get the boat moving, you need all the thrust that you can get, but only for a brief moment, just to get the boat moving, then you can back off the throttle since friction has gone down.
Also consider this, the acceleration or instantaneous thrust off the line may actually be higher than the curves. At low RPM, there is less airflow through the cage and over the prop, so there are fewer torque losses. More torque can go into making instantaneous thrust. Inertia of the prop and rotating equipment does subtract from the acceleration, but I am proposing that this is a small amount. I could be wrong here, one of these days I will model this aspect, but not now. :fishing
Have you ever noticed that a lot of times, the best way to get the boat moving is to stomp the accelerator and turn the rudder hard to make the boat jump on a turn? It will jump initially but then might stall out, standing on the throttle after that does nothing more, unless you rock the rudder. This may not be the case for you, but that is because you are using a double rudder set up and you have never seen how a big airfoil, single rudder can move a boat. But that is a whole other thread and discussion for another time! :stirpot: :stirpot: :stirpot: :stirpot:
Post by Slidin Gator » Fri Mar 02, 2018 12:35 am
To wrap this up, I think I have backed up my position sufficiently to say that OneBFC owes me a beer or two as payment on the original bet, or one hell of a rebutal. Quoting the original Challenge"
So, I challenge you, or anyone else for that matter, to explain, exactly, how any engine with more torque but less power will "move a boat" better than an engine with more power and less torque.
BFC said “Move a boat better” he didn’t say make more top end thrust. I am showing here that a motor with less power and torque capability has more performance range to move a boat in general use than the hot rodded set up. One answer would be that the “HP” set up just needs more gear. Yes, that would move the “HP” set up torque curve up and to the right, moving most of the useable power of the engine outside the range of interest for this set up (prop speed is limited after all). But I will let that simmer for now. :stirpot:
In the meantime, I suggest that if CMB has been saving up money to buy that SuperFlow LS Mast intake system, the money would be better spent on a keg, a band and a good party, or at least a few rounds of drinks. :drunken:
Again, if you want copies of the spread sheets this all came from, send me a PM with an e-mail address, Time to go talk Turkey, :fishing
Slidin Gator out. :salute:
OneBFC
Post by OneBFC » Fri Mar 02, 2018 2:39 am
Well, there is so much wrong with the book you just wrote I don't even know where to start really so I will just make a quick stab at it. I'll admit I'm a little annoyed at your post initially so, probably going to see that leak through in the following words a bit.
1. You haven't proven at all that a lower power setup will "move a boat" better than a higher power one here since you have chosen to place boundary conditions on your example that favors a very specific, misconfigured and narrow use case. And by "move a boat" you know full well I meant moving it on dry ground or with a heavy load. Why try to get sneaky here and and attempt to build a case where it's about the "power under the curve" and twist it into "Acceleration is what matters!"? (note that saying isn't "Torque under the curve".)
2. Limiting engine rpm to a lower than optimal value for that engine is really kind of disingenuous? Why not just tell someone that in order to move their boat better that they only apply 66% throttle? Who is going to swallow that? Is nearly 600 lbs of thrust worth discarding by limiting the engine so far below it's power peak? Does that "move the boat better" by leaving the engine close to it's torque peak and producing 600lbs less thrust? Come on man! Let's not forget that the engine in you example will make MORE thrust with LESS torque at the higher POWER level....because it's power you need to make that thrust...not torque.
If you are going to stand up on your torque soap box and try and convince people to limit their engines to a lower power level, gear it incorrectly and chose the wrong prop all in the name of keeping their maximum RPM at some predetermined level, well, I think it's extremely poor choice and will for sure confuse people. What your actually showing is that the amount of POWER difference between those two engines at lower RPM's is larger than the difference at higher RPM and one will accelerate more quickly than the other. The time difference to accelerate between those two engines will be quite small in reality because NO ONE is going to choke their engine artificially in the manner you are trying to propose doing and leave such a huge amount of thruts on the table. You wouldn't even build those two engines with a power curve like that if you were going to limit RPM ~1500 RPM below where they make peak power.
In the end here, you will probably come back with another 5 posts worth of highly massaged and modified graphs to try and convince someone torque is somehow producing thrust and is the most important thing to consider.
I was kind of hoping you wouldn't try and go this route to be honest. Maybe your joking? If so, man you got me good!
I can see you want to have long debates about this and you like trying to find a semantics angle to argue about vs the real topic. I really don't have any interest in that because it's a giant waste of time. You haven't, and can't, show how a higher torque and lower powered engine produces more thrust vs than lower torque and higher power engine. I suspect you know this but you want to continue rattling cages or something. In your crafted example you actually try to tell us that the engine with both less power and less torque is the better option and somehow "moves a boat" better than the higher torque and higher power one. That isn't exactly what the "challenge" asked for, now is it....
A properly designed engine optimized for power production at a reliable RPM combined with the right gear reduction to match up with an appropriate propeller is what should be considered by everyone. Throw your torque curves in the garbage (I like that one...) and just look at what power the engine makes at a given RPM and compare that to your other engine options. The engine that has the highest peak power will make the highest thrust, period. The engine with the highest average power (ie, power under the curve) will accelerate the best as long as peak power isn't too much less than the higher peak power engine.
So, in the end I think your "point" is that, to you, acceleration is SUPER IMPORTANT. Because that's all your keep saying really when you boil it down. You do know that at low prop speeds, they don't really need much POWER to turn, right? So, the time difference to go from one RPM to another is rather insignificant in human perception terms when comparing one engine that is using 25% of it's available power vs another that might be using 30% of it's available power. So, unless you grossly mismatch gear reduction it's really kind of hard to get into a poor accelerating propeller where you are waiting on it to spin up for a noticeable amount of time. Heck, my little ecotud makes no real power below ~2500 RPM due to the larger than stock turbo and you wouldn't know it to drive it. The large displacment engines most people use have more power at idle practically than my tiny little engine makes at full tilt and yet, no acceleration issues with my prop...snaps right up. How can that be if power at low RPM is sooooo important? The propellers just don't require that much power until their RPM reaches a critical point. If you select your gear and prop type properly then fine tune with pitch, the "snap" you are so concerned with is always there.
Btw, in one of your example graphs I think you didn't notice what the X axis units were because it sure doesn't support your torque argument. Take a look...Prop shaft....wuuuuut? oops?
Laslty, here's a really interesting quote from you:
Slidin Gator wrote:Just remember, a Torque curve plotted against RPM shows how the system will perform, jump, accelerate, cruise etc. across the whole operating range.
Gosh, I wonder, what would a Torque Curve plotted against RPM looks like and what would it be called? Oh, I know, POWER! What the heck? You are so confusing people with this stuf....But, that little nugget there is spot on. Torque at a given RPM as you so perfectly stated, is EXACTLY what people should use to judge their engine choices by and that is conviently known as Power.
We'll just forget you said this next part because it makes no sense at all and hey, I'm in the human club with you. I added the (engine) for clarity since I broke up your statement some:
Slidin Gator wrote:Hp tells you what it (engine) does WOT, assuming it is tuned correctly.
Look at that... you were a closet Power junky all along and you just didn't know it. Welcome to the club!
So, no beer for you yet....but I will offer you this :coffee2: so you can wake up and feel the power push you down recovery road.
:salute:
-Russ
Williamalvin
Post by Williamalvin » Fri Mar 02, 2018 3:35 pm
I know there has to be one engineer in this thread and it sounds like explanations have been poorly conveyed due to excessive explanation.
First HP does not move a boat force does so wrong formulas are being used. F(thrust)=m(prop)xacceleration(related to torque). This would conclude that you have same prop then only way to make more Thrust is to accelerate faster which requires more torque. This is what concept is trying to be conveyed across and RPM range.
Second let me put this in simple perspective. If you slowly lean your weight onto a car it will more than likely not move, but if you fall into a car with same person it will shake because you have accelerated the mass.
Both of you can be right depending what you want to look at. Remember power is torque applied over a time so it is not doubt the work torque or distance in certain time is. Eventually at 5400 rpm you have made it spin fast enough to create more torque in same time so result is more thrust.
Without being to long hardly anyone is ever at 5500 rpm’s for more than couple minutes which is why the concept of operating ranges exist so where do you get the best force over a time period that can be a good question and think the intent of the subject.
OneBFC
Post by OneBFC » Fri Mar 02, 2018 4:03 pm
Williamalvin wrote:I know there has to be one engineer in this thread and it sounds like explanations have been poorly conveyed due to excessive explanation.
Oh there is an engineer here for sure and some misguided types as well that for some reason refuse to open a book or read any of the reference material I keep linking.
So, to a point, you are wrong too, just like all the other torque camp people. Saying power doesn't move a boat clearly illustrates you don't understand yet.
Read this material, please?
http://s6.aeromech.usyd.edu.au/aerodyna ... and-power/
Nowhere will it reference torque as a value needed to determine thrust.
All your low rpm torque translates to is.....power available at that rpm.
Torque does ZERO work. Power does work. Power makes thrust.
As to your leaning on a car analogy, you are describing what is known as "jerk". That's a giant door for a joke here obviously, but that is the correct term.
Here is a link to understand Jerk better.
https://en.m.wikipedia.org/wiki/Jerk_(physics)
Again, no one is suggesting to use a narrow power band engine. Regardless if it's a high rpm or low rpm type.
And honestly, you really don't want a bunch of power at low rpm because you will have to keep the throttle plate closed mostly and that will increase the pumping losses of the engine. If you have less power at low rpm, but still enough to meet the prop needs, your throttle will be open further and you will incur less pumping losses and better fuel efficiency. This is one reason why diesel engines get better fuel efficiency. They don't have a throttle plate and are always WOT from an air intake perspective.
-Russ
digginfool
Post by digginfool » Fri Mar 02, 2018 4:41 pm
Slidin Gator wrote:Have you ever noticed that a lot of times, the best way to get the boat moving is to stomp the accelerator and turn the rudder hard to make the boat jump on a turn? It will jump initially but then might stall out, standing on the throttle after that does nothing more, unless you rock the rudder.
You somewhat touched on the answer already in that static friction is higher than dynamic friction. The only thing that will get a boat moving is to overcome the 'stiction' or holding force of static friction. The real answer is in moment-arm. When the rudders are pointed straight, the only moment-arm at work is the thrust times the distance above the ground. This increases the 'weight' of the boat (the amount of downward force) which increases the static friction (total vertical force - actual weight of boat plus the force of the moment-arm of thrust x distance above ground - times the coefficient of friction). However, move the rudder and now you have a moment-arm that acts at the rear of the boat which is a certain distance from the center of gravity and causes the boat to rotate about the center of gravity. Now, once the boat rotates, you have broke stiction and now only dynamic friction is at play unless, as you suggested, the boat does not have enough power to continue to overcome the dynamic drag and gets pulled to a stop again. Of course, you could continue to 'shake your rudder' keeping dynamic friction alive. As a side note, disturbing the ground by rocking the boat side to side can also pull moisture up which also helps reduce frictional forces. Just the engineer in me coming out. 8)
