New to airboats Corvair powered what’s it worth
Dawsonby19
Post by Dawsonby19 »
I’m looking to buy my first airboat. I don’t know to much about the boat other than it has a Corvair motor it has been sitting a long time. The boat is 16ft long by 6ft wide. My main question is will this boat have enough power to get on plain and what would it be worth? I’m not sure about the prop and the guy that’s selling doesn’t know cause the original owner passed away any help would be great. Thanks!
Andy
Re: New to airboats Corvair powered what’s it worth
Post by Andy »
Jmo. I would pass
BenBad
Post by BenBad »
JMO, I would pass also. I had a 14 X 6 as my first boat. The hull is to narrow. A wider hull will give you more stability. I have never heard of anyone that has been happy with a Corvair engine. Please put where you are located in your profile and maybe someone in your area will know of something that would fit you and your budget better.
Rick Powers
Omaha NE
http://www.yourtalkingnow.com/
Post by kwanjangnihm »
Andy wrote:Jmo. I would pass
x3 :thumbleft:
Dawsonby19
Okay thanks for your guys input. I’m from Pennsylvania and there’s not to many air boats around just happen to find this one local and was going to go for it.
Dawsonby19
Would it be something I could use like it is then put a bigger engine in?
radtech
Post by radtech »
6 ft wide is narrow even for a 12 ft airboat. At 16 ft, you need an 8ft wide bottom. I would not mess with it if I were you. Too many affordable airboats out there to buy something you KNOW isn't gonna work out
A wide boat is so much safer.
