Jegs blue print enginr
Moritz
Post by Moritz » Mon Aug 27, 2018 1:56 pm
Any used the 383 or the Ls engines from Jegs in an air boat? Any problems?
Re: Jegs blue print enginr
Post by SWAMPHUNTER45 » Mon Aug 27, 2018 9:05 pm
If you dig in the archives you will find info but to make it easy the answer is YES
Yes people have
Yes they have had problems
Yes they have had some success
If you go with a 383 spend the extra money to upgrade to the roller version and make sure the engine does not run lean.
Prototype
Post by Prototype » Mon Aug 27, 2018 9:22 pm
Well that's an open question but to date I don't think Jegs sell's White engines so it's still buyer beware, or buyer be warned!
There is no cheap version of anything that lasts and people still don't realize the cheap versions break when you need them the most!
There was some on here that had luck with the zz versions from GM, "not Jeg's specific" but a decent GM build. I still like mine built for 6k for 2 minutes. Those specs hold up real nice but not a cheap build.
Moritz
Post by Moritz » Mon Aug 27, 2018 11:22 pm
Who build a 383 engine or a Ls one?
Post by SWAMPHUNTER45 » Wed Aug 29, 2018 8:30 am
What exactly are you looking for power wise and how much can you afford to spend? What prop do you plan to spin and do you have a gear drive ratio? As has been discussed on here in great detail an airboat engine needs to be purpose built to have longevity. Like Proto said some people have gotten by using the ZZ4 and based on the answers to the questions the SA family can offer up advice.
Moritz
Post by Moritz » Tue Sep 11, 2018 1:46 pm
2:68 ratio on. 7 by 15 Hull
Moritz
Post by Moritz » Thu Sep 20, 2018 7:02 pm
Looking to put an engine on old school metal 15’ panther with a 2:68 gear drive want 390 + hp
Hotdog
Post by Hotdog » Thu Sep 20, 2018 8:34 pm
I have a 358 I built and never used, very good parts in it. 13-1 compression. Worked RHS vortec heads custom going can, crane rollers, titanium retainers and keepers. Should be at least 450 hp
Hotdog
Post by Hotdog » Thu Sep 20, 2018 8:37 pm
Ground cam. Sorry. Auto text
Post by One Eyed Gator » Fri Sep 21, 2018 7:57 am
I just budget built a 6.0 that is around that HP, I bought used and redid top end. I have a 2.68 with a 79" 3 bld R it is on a 14' Alumitec runs fairly well. It is certainly not purpose built, might blow-up tomorrow. Had a stock 5.3 that had 113K before it was on 2 different boats over 300hrs on 1 and 192hrs on mine, still running strong when it came off a month ago.
You can get LS2 Block from scoggins-dickey for 1200.00 and LSA forged crank for just over 400.00. Look at the the Scoggins web-site they have some good pricing.
Sent you a PM
OEG
loudmouse
Post by loudmouse » Mon Oct 01, 2018 10:41 pm
That crank is almost $700 nowadays. The blue engines have been used on airboats but they don't live long. I know of 3 that died short of 50hrs.
Built and Tuned by Me
