Going to have new boat built soon
Coastslider
Post by Coastslider » Tue Feb 19, 2019 7:06 pm
I’m going to have a new boat built by GTO in the very near future. Either 16x8 with 509 BBC or 15x8 with LS3. Both will be 3/4 deck walkarounds. BBC is 520hp/610ftlbs torque, LS3 is 550hp+/560ftlbs torque and all aluminum supposed to weight about 390lbs or so. Question is longevity. Which one do ya’ll think would last longer ? I don’t really care about fuel consumption so that topic doesn’t matter to me.
OneBFC
Re: Going to have new boat built soon
Post by OneBFC » Tue Feb 19, 2019 7:48 pm
LS3 out of those options hands down. more power, less weight, easy parts and at that power level all day long reliable.
Good luck!
-Russ
Coastslider
Post by Coastslider » Wed Feb 20, 2019 12:22 pm
Thanks Russ
scottyroll
Post by scottyroll » Wed Feb 20, 2019 2:04 pm
X2 on the LS3. Especially if you are going to run any saltwater. My family's 502 has some some nasty rust areas for staying out around steinhatchee and pretty much only running salt water when we do take it out.
:Scotty-Roll:
FLAwless
Coastslider
Post by Coastslider » Wed Feb 20, 2019 5:32 pm
All I run is Saltwater
Post by SWAMPHUNTER45 » Wed Feb 20, 2019 7:03 pm
OK well I'm for the bigger boat and BBC
It will just be a more enjoyable ride since you are going to be a Gulf boat.
barhopper
Post by barhopper » Wed Feb 20, 2019 7:52 pm
15 x 8 with the LS3. I run a 16 now but I’d get a 15 if I did it again. GTO builds a nice boat. I’ve beat the crap out of mine for almost 14 years and it’s still in good shape. On the fourth poly bottom now. I run the gulf 95% of the time.
unforgiven11B
Post by unforgiven11B » Wed Feb 20, 2019 8:03 pm
I run 16x8 with a PCM/Levitator 6.0 325ish HP, 12” walk arounds, three blade sensenich K series. Boat was Hillsboro county’s . I go where I want no issues. Ran all of Kissimmee last weekend seen tons of boats stuck. If it was me I wouldn’t run a BBC over the LS3 on a boat this size. On a larger boat or a 16x8 tour boat,6/8 pac would do the Id go 540. I run the gulf I little I also have a deep boat. As far as reliably there is tons of LS powered airboats with 1000’s of hours on the clock and still going just fine. I’ve also heard a lot more 502’s failing than LS powered rigs.
Mossy Cypress
Post by Mossy Cypress » Wed Feb 20, 2019 8:17 pm
I say go with the Ls, that is plenty of power to push a deep sided 15x8 and should be a point and go boat loaded down. Has to be a reason most car motor boats being built now are Ls powered. More power,less weight,plenty reliable.
