Carb question?
Shippee123
Carb question?
Postby Shippee123 » Tue Mar 12, 2019 1:24 pm
I have a 13'6 alumitech with a 454 dd on it.
I use it primarily for gigging and riding. With the boat idling around if anyone moves from one side to the other or another person moves forward my idle jumps up 3 to 4 hundred rpms. I am thinking something to do with float level due but I am not an carb person. It has an edelbrock 4 barrel on it. Carb is setup as it came out of the box.
Should it be adjusted differently being it's on a boat that rocks back and forth? Runs great on plane and idles great just has the fluctuation at idle with movement.
Any help is appreciated
Art Shippee
Sent from my [device_name] using [url]Southern Airboat mobile app powered by Tapatalk[/url]
Rich Andrews
Re: Carb question?
Postby Rich Andrews » Tue Mar 12, 2019 2:14 pm
Never run a carb traight out of a box if you want to preserve the longevity and performance of the motor. Send it to someone who is an expert. Money well spent
LOHA is AHOL backwards
Re: Carb question?
Postby One Eyed Gator » Tue Mar 12, 2019 2:55 pm
What he said^ I have seen all kinds of bad stuff in out of the box carbs.
Get the manual and make sure every thing is correctly set-up ie float. Also look up tuning an Edlebrock. It is very basic and easy to tune. I have put 3 of them on buddies airboats (against my recommendation) and all required some type of tuning. All required different spring, metering rod and secondary jet. All 3 were very rich at WOT and Idle.
Rich Andrews
Re: Carb question?
Postby Rich Andrews » Tue Mar 12, 2019 4:22 pm
9548815249- Ed MAck im his biggest fan and you will never get screwed over by the man. Just sent him a stubborn 1/4 mile guy who knew it all and said dam I was leaving a lot on the table
dodobird
Re: Carb question?
Postby dodobird » Thu Mar 14, 2019 11:41 pm
Take that carb off n throw it in the dirt edelbrock should have never started building carbs they dont know what they are doing
13' laser 360sbc oxdrive 2.68 .... 80" 3 blade whispertip ex :florida:
Re: Carb question?
Postby SWAMPHUNTER45 » Fri Mar 15, 2019 7:31 am
My experience has been just the opposite the Edelbrock Thunder AVS series work great for me and I would recommend them. If your near Brooksville give Buddy Branch a call he has all the jets and parts to dial it in. They just started making a 650 annular booster that is awesome for the direct drive engines.
Shippee123
Re: Carb question?
Postby Shippee123 » Sat Mar 16, 2019 4:19 am
SWAMPHUNTER45 wrote:My experience has been just the opposite the Edelbrock Thunder AVS series work great for me and I would recommend them. If your near Brooksville give Buddy Branch a call he has all the jets and parts to dial it in. They just started making a 650 annular booster that is awesome for the direct drive engines.
Thanks
Users browsing this forum: No registered users and 6 guests
