632 overheating at idle
stickittoem
Post by stickittoem »
Mas All aluminum fuel injected 632
What happened-was out gigging and was packing up ready to make the run back in and the temp was about 220. Shut off and it pissed coolant. Let it cool off for about 30 minutes then topped off with water. Made the 8 mile run back in with no issues. When I came off plane to idle to the dock the temp started to rise.
-replaced two thermostats
-replaces water pump
-made sure no air pockets in system
-check radiator flow
None of these procedures fixed the issue
Now resurfacing heads and new head gaskets.
Trying to figure out my next step if this doesn’t fix it. Please chime in if you have any input. TIA
airduds
Re: 632 overheating at idle
Post by airduds »
How long have you had it?
Rich Andrews
Post by Rich Andrews »
Why are you re surfacing the heads?
Rich Andrews
And how lean do your plugs look? Could be just the carb
Rich Andrews
or in the timing at idle? Did u check that?
stickittoem
34 hours
It’s fuel injected peeps
Checked all timing
We just found the problem
stickittoem
Butterfly screw went through cylinder 4
Rich Andrews
That sucks big time.... sorry to hear that
Rich Andrews
Make sure to delete that screw next time..no need for it
What Pistons are in that engine ?
I assume your going to call Mike and try to get a replacement of the exact weight.
