Performance Unlimited
MissGuided
Post by MissGuided »
Has anyone here had experiance with Performance Unlimited, do they build reliable LS motors for airboats?
PAINKILLER
Re: Performance Unlimited
Post by PAINKILLER »
I have never heard of them until I saw a video on YouTube can't say good or bad but I would go with Mast for a LS engine they were recommended buy another engine building company this company told me they make the best cylinder heads out there
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
Ribcracker
Post by Ribcracker »
I have, unfortunately !!!
digginfool
Post by digginfool »
Mast is a good choice but put your money down and buy a Waterthunder. You won't go wrong. The engines are built from the crank up to be used in an airboat. Dave has put tens of thousands of hours into his designs and they work. If I had it to do over, I would have gone that route.
PAINKILLER
That is true waterthunder performance does have motors out there with thousands of hours on them still going strong but me I'm going to Mast
MissGuided
I talked to Dave at Waterthunder on Friday, calling him today with deposit.
Thanks for the reply!
PAINKILLER
Good luck on the new motor what size are you getting
MissGuided
Ordered the 416, 600 hp. It's going on a 14x8 riveted hull by John Fenner
PAINKILLER
👍10/4 should haul the mail for sure
PAINKILLER
If I was to order one from him it would be one of his 500 cubic inch LS motors with mast 305 heads on it and the XR composite intake
MissGuided
Going from a DD 350 on a glass boat I would expect a slight performance improvement
PAINKILLER
That is very true 👍 but I will say I was only speaking of what I would do and not what someone else should do post a video of it running on the boat like to see how it does on the water
Robo
Post by Robo »
You made a good choice, I bought a motor from Dave two years ago put it on a 15 foot Hamant, great motor.
akmike30
Post by akmike30 »
For Ls go with Dave at water thunder. Money best spend. I have over 150 hours on my motor I bought this spring. Not one issue.
I was that guy doing the same thing. So glad I went with his motor. pushes my Alaska airboat everywhere I point it and sips the fuel with 87octane Image
MissGuided
Lots of work to do, hope to have my hull by December, metal work, paint, fit n finish, might be January but I will post as work continues.
That Alaska boating looks crazy!
