Crusader 502xl ECU.
dcm5899
Crusader 502xl ECU.
Post by dcm5899 »
Anyone know a good repair/reprogrammer for GM Marine ECU in Florida. I have a 1995 Crusader 502xl and I believe the ecu quit working, it won't turn on power to the ignition coil or fuel pump
keys2pines
Re: Crusader 502xl ECU.
Post by keys2pines »
Check the service manual and look for relays for that engine. I had a 29" phoenix with twin 1996 Crusaders. I had the same problem, thought the fuel pump went bad, ended up being a relay in the wiring harness.
dcm5899
Post by dcm5899 »
I did, put two new ones in. Hot wired fuel pump when it wouldn't restart while out on the water, but it's not sending power to the coil either
Thanks
dcm5899
Post by dcm5899 »
It was the ECU, so don't let "an expert" bullshit you that the ecu doesn't control fuel pump.
keys2pines
Glad you got it sorted out!
