engine weight
grassblaster
engine weight
Postby grassblaster » Wed Jan 09, 2008 2:16 pm
what does a chevy 350 weigh also what does a 4.3l v6 weigh
If you aint stuck you aint airboatin!!
bondsman
Postby bondsman » Wed Jan 09, 2008 2:29 pm
did you use the search function yet.there is even pics of different enginrs on scales in some of the posts.
FELBER632
Postby FELBER632 » Wed Jan 09, 2008 2:43 pm
Dave has a lot of that data. I lost years of weight data a couple years ago when I lost a hard drive in my computer (Note to other dummies like me who don't back up their stuff). So currently I'm having to re-log engines as I weigh em.
Today's weigh-in was a 502/502 complete from carb to pan. Oil, distributor. heavy JW Wheel, cast iron water pump, steel pulleys and motor mounts. All that was missing is the starter and distributor. It weighed exactly 590#s without redrive..
Felber
Waterthunder
Postby Waterthunder » Wed Jan 09, 2008 3:00 pm
Cool we need to get together and try my digital scale, For my own personal reasons I want all my engine weight data to be from one common scale! Let me know when my intake is done and I will bring my scale bye!
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
grassblaster
Postby grassblaster » Thu Jan 10, 2008 12:04 pm
does anybody have any more ifo Thanks
keebo
Postby keebo » Thu Jan 10, 2008 2:45 pm
Chevy 350 between 535 and 575 depending on accesories
the v-6 around 425 8)
:old_glory: :florida: :GA:
josh_2562
Postby josh_2562 » Thu Jan 10, 2008 7:10 pm
Got this from another post
440 mopar 670lbs
455 buick 600 lbs
lycoming io-540 515lbs
472-500 caddy 595lbs
351w ford 510 lbs
429-460 bbf 640-720 lbs
454 bbc 675lbs
350 sbc 575-600lbs
carpshooter1
Postby carpshooter1 » Thu Jan 10, 2008 7:26 pm
a year ago we cnc machined a block for our boss's stock car the long block weighted
330lbs
we machined all of the water jackets to a thickness of .150 took out any extra webbing (like between the bolt holes for the bell housing) around the timing cover mounts cut out valleys over the cam
basically the grand work over its still running but who knows when it will let go :shock:
ONE MINUTE AT A TIME YOU CAN'T CONTROL ANYTHING ELSE
14FT GPU- BIG FUN
MikeP
Postby MikeP » Thu Jan 10, 2008 7:30 pm
Thats bad ass Carp. Look on youtube, there are videos of all aluminum blocks being machined on 5th axis, some awesome shitl.
mudkat
Postby mudkat » Fri Jan 25, 2008 2:37 pm
i have a 350 chevy iron heads ,alum intake ,no carb ,headers ,starter, flywheel ,dist ,but no water pump with oil in it ,it weighed 520 lbs on my new certified digatal hanging scale,I also weighed a 215 buick that all aluminum it weighed 315 pounds.
Cracker0320
Postby Cracker0320 » Fri Jan 25, 2008 3:41 pm
The GO-300 dry Weight is 311.92 lbs.
Overall Engine Dimentions:
Height 27.62" -A,-B, 26.56" -C,-D,-E
Width 31.50"
Length 39.12" -A,-B & C, 39.19" -D & E
The IO-360 dry Weight is 331.25 lbs.
Height 22.43"
Width 31.46"
Length 34.03"
The O-470 engine dry Weight is 379.66 lbs.
Height 28.09"
Width 33.56"
Length 36.03"
