4X8 Wood boat build.
Salty Techsan
Re: 4X8 Wood boat build.
Postby Salty Techsan » Wed Nov 06, 2013 7:50 pm
and a couple more...... fyi.. this was my first time to ever work with metal tubing in any way, shape or form... bending was a lot easier than I had expected.. but making the saddle cuts and welding the thin wall stuff kicked my ass!
Gg Kustomz
Postby Gg Kustomz » Wed Nov 06, 2013 8:53 pm
Salty Techsan wrote:and a couple more...... fyi.. this was my first time to ever work with metal tubing in any way, shape or form... bending was a lot easier than I had expected.. but making the saddle cuts and welding the thin wall stuff kicked my ass!
That looks awesome! I cant wait to see how that 32 does for you. I have found when welding EMT that stitch welding helps out ALOT. That is going to be a cool boat. Are you doing 4x8?
Salty Techsan
Postby Salty Techsan » Thu Nov 07, 2013 9:23 am
hull is 9'6" LOA with a 60" beam.... 48" flat bottom, with 6" of no trip chine on either side of that.
southern poison78
Postby southern poison78 » Sun Nov 10, 2013 9:58 am
If inst i have a 42 24 wood prop and hub new and riging up fir sale or trade and a corvair 110 engine also if inst let me know
14' stump jumper fiberglass hull 500 caddy kayway reduction gear whirlwind sw 78 quickslick
southern poison78
Postby southern poison78 » Sun Nov 10, 2013 11:20 am
I have a 42 24 wood prop and hub for a mini and rigging also have a corvair 110 engine if anyone is inst
Gg Kustomz
Postby Gg Kustomz » Wed Nov 13, 2013 8:26 am
southern poison78 wrote:I have a 42 24 wood prop and hub for a mini and rigging also have a corvair 110 engine if anyone is inst
How much HP on the motor and how much are you asking for?
Gg Kustomz
Postby Gg Kustomz » Fri Nov 15, 2013 7:37 pm
Hey buddy how is your build going any more pic's?
DDPWRD
Postby DDPWRD » Sat Nov 16, 2013 12:21 am
Exactly weld for a sec n stop n go n so forth works great. I build my rigging and in 2yrs the only weld to break was the step goin up.and that was using a gasless mig.
BLOWIN THE WIND
Salty Techsan
Postby Salty Techsan » Mon Dec 02, 2013 4:17 pm
thanks for the education on stitch welding... link below is to some of the build photos... I don't want to hi-jack the thread, so I'll eventually post a new thread with all the detail. We will now clean up the metal work, slap on the welded wire to the cage and paint a desert tan camo scheme.. the red was just a pigment we added to the epoxy resin we used for the heck of it.. Boat is really fun, and perfect for my kiddos.. I think the hull weight got away from me a bit, and I have a little too much prop.. (3 bld, 44" diameter, 12degree pitch).. she is only turning 2300 RPM WOT. Not sure where I missed on the propping.. I remember Papee saying he was running a 3bld, 44" ultra at 12 degrees... which is why I chose the prop I did. Not sure if I'm not getting all the "ass" out of the motor I should be? or if I really do just have too much prop? I any case.. the boat is very fun in shallow water.. it handles great, and feels very stable and safe, which is What I wanted for my boys. Very fun project!! thanks to all who helped us along the way!!
https://plus.google.com/u/0/photos/1010 ... plp0&hl=en
Airboat_Fever
Postby Airboat_Fever » Tue Dec 03, 2013 10:09 am
how did you bend your cage hoops?
When No one else can get out I CAN!
___________________________
The VERY FIRST 13' Fiberglass AIRGATOR with Direct Drive Smallblock Chevy 72-32 paddle
in the works 10' 6in. by 7' Apache hull with 4.3 Direct Drive
Salty Techsan
Postby Salty Techsan » Tue Dec 03, 2013 1:54 pm
drew out the arch on a sheet of plywood, and drove framing nails as I went, starting at one end, and bending the tubing around the nails as I went, using the pencil mark of the arch to follow as a guide.
Shoshinru
Postby Shoshinru » Mon Aug 24, 2015 9:40 am
Gg Kustomz, What type of glue or epoxy did you use in your build? I've "kitted" my Lake Buggy Airboat and ready for assembly. Epoxy doesn't agree with me and I was thinking about using Titebond III along with SS screws. Thanks for any imput.
Caddellwelding
Postby Caddellwelding » Mon Sep 07, 2015 10:30 pm
3M has some marine grade stuff that's bad A!
Sent from Caddell Welding L.L.C
Return to “Mini-Airboats”
Users browsing this forum: Yahoo [Bot] and 2 guests
