I just picked up a couple of 4a084 generator motors cheap. One is complete the other is missing a head and starter. I'm not sure how to try and start the one that's complete. Any advice would be appreciated. If I can get one to run good I plan to start a mini build with it.
Thanks,
Dan
4a084
- nebraskaairboater
- Site Supporter - I
4a084
Dan Porter, Jr.
Fremont, NE
Fremont, NE
Re: 4a084
will the starters are 24 volt if its stock and u need to check for spark add fuel it should run most of the ones I have got in to hard burned up rotors in the mag and dirty points
new rivermaster by marty bray,12 x 7.6, stainless rig with pancake cage,2011 chevy cruze 1.4L turbo LUJ,gm ecm controlled, cat converter with evap system, 2:1 drive by century drives,water walker 3 blade cypress 68 in,1/4" gpx polymer
- Site Supporter - III
Re: 4a084
Fuel: check
Compression: check
Oil & filter: check
Spark: check.
If the mag is bad, most any other 4cyl mag will work, SaturnSurplus.com had some new ones for about $150.
http://saturnsurplus.com/aircraft/10kslick.htm
The 24V starter will turn on lesser voltage, only slower.....it's easy enough to series two batterise together for 24V.
Often engines turned in or otherwise in storage will have all the fluids drained; pull the plugs, squirt a little oil in each cylinder, if the crankcase is full (and filter attached) spin it over to get everything lubricated & flowing, would be a good time to check the spark on each plug while you're spinning it over, make sure the shut-down switch is working and "on" when you check for spark and to run it.
May take a little while to pull fuel through it, seal the cylinders, get everything wet, but shoud all three things cometogther it should run!
Compression: check
Oil & filter: check
Spark: check.
Mother Nature plays to win, and if she doesn't get you, her bitch of a daughter Krama will.
- nebraskaairboater
Re: 4a084
I have an opportunity to pick up a broken 4 blade warp drive setup with the plates and all hardware. The blades are shot but replacements are cheap. Would this work as a 2 blade for the 084? Either with reduction or direct drive?
Thanks,
Dan
Thanks,
Dan
Dan Porter, Jr.
Fremont, NE
Fremont, NE
