Caddell's Build 2.3L turbo
Caddellwelding
Postby Caddellwelding » Tue Apr 19, 2016 9:14 am
Is there a gear box for a ford 2.3L turbo?
southern safaris
Re: Caddell's Build 2.3L turbo
Postby southern safaris » Tue Apr 19, 2016 10:02 am
Rotax's not doing it for ya anymore :stirpot:
Hughes Airboats and Fabrications
580-228-5782
Aluminum round-sided hulls
Caddellwelding
Postby Caddellwelding » Tue Apr 19, 2016 1:05 pm
Ya it's fine. I have a buddy that runs those motors and he said they are bad a**! Just curious if there was a gear box for one. Wraspy engine for sure.
OneBFC
Postby OneBFC » Tue Apr 19, 2016 4:51 pm
Is this a new Ecoboost 2.3? The older ones are very potent too if built properly. The new 2016 Focus 2.3 ecoboost comes from Ford with just shy of 350hp. 90% of Max torque at 2000 RPM, so 300 ft lbs at 2000 RPM. Impressive no matter how you look at it.
That is Bone stock.
Older 2.3's make good power too, but will have the power come in at much higher RPM vs the ecoboost version.
Yes, will make a very nice engine for airboat use.
Just make an adapter plate and bolt gear box of choice.
Good luck on your build.
-Russ
400+hp Ecotec, 12x7.6 DBDO, 80" 3B Maximus, 2.3 OX,70+mph, water = purely optional
Caddellwelding
Postby Caddellwelding » Tue Apr 19, 2016 9:38 pm
A buddy of mine has that motor on a dune buggy. And it flies, has superb hope power and is fuel efficient. Thank you for the info!
Caddellwelding
Postby Caddellwelding » Tue Apr 19, 2016 9:41 pm
It's only $7,500! Wow!!!!!
Return to “Mini-Airboats”
