12-14'/Rotax 582 Performance Questions
AlaskanOutdoorsman
Postby AlaskanOutdoorsman » Mon Mar 20, 2017 2:41 am
Does anyone have first hand information on 12'-14' mini's (aluminum not fiberglass) running Rotax 582's? Specifically, I'm curious how heavy your hulls were, how they pulled, where you ran, if you had a poly bottom or ran frog-spit, etc., what they could haul, and to see if anyone did any thrust tests with their set-ups. I just sold the 582 grey head on my 12' boat and trying to determine how much more HP I need vs want before I install the new engine and begin the redrive process. I live in Alaska and use my boat primary to hunt. Thanks in advance.
papajack
Re: 12-14'/Rotax 582 Performance Questions
Postby papajack » Mon Mar 20, 2017 8:20 am
PM sent.
Postby kwanjangnihm » Mon Mar 20, 2017 8:44 am
viewtopic.php?f=57&t=66510
thread build using a rotax and aluminum hull
southern safaris
Postby southern safaris » Mon Mar 20, 2017 9:43 am
www.facebook.com/hughesairboats
There are some videos on there of a mini i built for a fella , its running a kawisaki 440 which is around 40hp its 12' ran well with two and some dry with 1 , wind seemed to knock the stuffn out of her though, im not a mini advocate per say but it did suprise the hell out of me , we are doing the same hull with a 103hp geo metro engine and reduction next , i think i have full build pics stashed away somewhere if you want them ill have the wife try and upload them when we get back in town
Anthony Hughes
Madison FL
850-973-2642
580-228-5782 cell
Aluminum round-sided hulls
Caddellwelding
Postby Caddellwelding » Wed Mar 22, 2017 12:33 am
I built a 6'x12' mini with a 503 dual carb rotax on a alum hull. It performs great, runs 40mph with two guys. I'm currently doing some changes to it. Overall I'm happy with it. Need anything let me know!
Dan Richardson
Postby Dan Richardson » Thu May 04, 2017 8:09 am
Hi i have a rotax 582 with 72 "4 blade wrop drive and i'm haveing a hard time finding hulls for it do you have any advice. i have found one 11 x 7 hull that weighs 205 lb. is there liter min hull that you know of thank you Dan
Dan Richardson
Postby Dan Richardson » Thu May 04, 2017 8:10 am
My email is fdr045@msn.com thanks
Return to “Mini-Airboats”
