Post
by glades cat » Sun Oct 08, 2017 9:43 pm
Airboats can be tippy. Engines mounted high and prop torque affect this. 48" is not a very wide hull.
A Jon boat with an airprop is not an airboat. Same as a bicycle with an engine is not a motorcycle.
If you're determined to build it you'll find its limitations quickly.
Just trying to steer you in the right direction.
