Newest Creation from Angels Airboats
airboat angel
Re: Newest Creation from Angels Airboats
Postby airboat angel » Thu Jun 05, 2014 10:27 am
NHRA top fuel runs blon motors. I can run any fuel I want. Dont wanna spray - thats all !!!
They run nitro methaneon blown motors.
:angel4:
airboat angel
Postby airboat angel » Thu Jun 05, 2014 10:29 am
Actually we are not looking for a pissing match - but would love to come out and play and see what it will do. As soon as its ready 100%.
Will let you know.
:angel4:
Tony480
Postby Tony480 » Thu Jun 05, 2014 11:13 am
You say your a Dart dealer and builder...what's your business name....I did a search on Darts list of dealers and what not and there is no business that matches your name or anyone near your location.
gchuckie
Postby gchuckie » Thu Jun 05, 2014 12:17 pm
airboat angel wrote:NHRA top fuel runs blon motors. I can run any fuel I want. Dont wanna spray - thats all !!!
:angel4:
I know what motors they run and what fuel they run. :thumbleft: Any time you run a power adder or a force inducted motor you take a chance! Nos is just one of the cheap ways to add power if it is setup right..
Dan520
Postby Dan520 » Thu Jun 05, 2014 12:22 pm
ive raced for several years from everything from bracket racing to pro mod, with na motors, nitrous, blowers, and turbos...its usually the tune up with nitrous that causes the damage not the nitrous itself, but then again ive seen several blower motors not make it either. Nitrous is cheap easy power but dont blame it for blowing up motors
13.6 gilleo, true 520 cont, 40" light headed bar, 74" NGQ
"under construction"
"When In Doubt...Throttle Out"
airboat angel
Postby airboat angel » Thu Jun 05, 2014 3:03 pm
Sorry if you misunderstood. I didnt say it was the main cause - just that it always seems to happen when you spray a motor more so. I have also raced .
:angel4:
Tony480
Postby Tony480 » Thu Jun 05, 2014 3:29 pm
Tony480 wrote:You say your a Dart dealer and builder...what's your business name....I did a search on Darts list of dealers and what not and there is no business that matches your name or anyone near your location.
Well??
airboat angel
Postby airboat angel » Thu Jun 05, 2014 4:00 pm
Well Tony we may not be on thier dealer list as of yet but we have been a dealer and manufacturer for many years with them. You can actually call there and ask them personally !!! Ask for Rick.
:angel4:
We are a dealer for many many companies....
Angels Airboats
Last edited by airboat angel on Thu Jun 05, 2014 4:18 pm, edited 2 times in total.
airboat angel
Postby airboat angel » Thu Jun 05, 2014 4:05 pm
Here's a little tip on fuel delivery that some of you were wondering about earlier...
an 6 thru an 8 will deliver enuff fuel for 750's up tp 1350 dominators or quadrajets. Just look it up at russell fittings !!!
It's fuel pump;rails;and know how.....
There is always someone questioning something. LOL.
:angel4:
Anything else???
airboat angel
Postby airboat angel » Fri Jun 06, 2014 9:42 am
Latest tech tip for those interested; lets say you are running 88 main jets x 4 ; which equates to 352mm per carb which is less than 1/8" if you run 3/8 line to that carb it can only run 7 psi max. where does the additional fuel go ? if you run dual carbs same set up you still have an over delivery of fuel.if you run 8 an to a fuel bar delivering 7 psi with a by pass of anything over your motor will not lean out or have a fuel delivery problem. one thing to remember you must have a fuel pump with a by pass to ensure 7 psi continuous flow. this will supply carbs up to 1350 cfm dominators. bigger fuel lines just means bigger money not performance. hopefully this tip will help some of you home motor builders. its physics - not always bigger is better. gotta feed them carbs !!! any questions i will do my best to help you understand this.
Bdriller
Postby Bdriller » Fri Jun 06, 2014 11:02 pm
I have 3/4 inch fuel lines on my dd caddy and it runs fine uh wait , sorry my bad those are my heater core hoses!
ptr34
Postby ptr34 » Sun Jun 08, 2014 4:26 pm
Lake races . Ill have the twin turbo back by july ;)
I want some too. And its a ride boat.
tons videos on YouTube ptr34
fl cracker
Postby fl cracker » Sun Jun 08, 2014 4:44 pm
With 3,000 hp there's not a boat that will touch it lol.
" I have two guns...
One for each of you "
2012 12'-6" x 7'-6" Hamant with a SV 540 & NGQ's
Bubba
Postby Bubba » Sun Jun 08, 2014 5:29 pm
fl cracker wrote:With 3,000 hp there's not a boat that will touch it lol.
All I got is 450 lol.
FLIRTIN WITH DISASTER
big3country8
Postby big3country8 » Sun Jun 08, 2014 5:50 pm
What about your motor bubba? You forgot that horsepower.....
Temporary High
12' clendenin aluminum step with poly, 418 waterthunder, 2.68 OX, 9 blade saber, ATF rigged, nitrous outlet,, buttrax custom seats.
swampdragster
Postby swampdragster » Sun Jun 08, 2014 6:02 pm
I dont think he wants to race, maybe tractor pulling would be more his thing.lol
UNLIMITED SWAMPDRAGSTER DRIVER
QUICK SLICK on every dang thing!!!!
swampdragster
P.Vento
Postby P.Vento » Sun Jun 08, 2014 7:36 pm
swampdragster wrote:I dont think he wants to race, maybe tractor pulling would be more his thing.lol
nobody wants to race anymore, just talk about it
HAMMERHEAD
Postby HAMMERHEAD » Sun Jun 08, 2014 9:17 pm
I DO!
airboat angel
Postby airboat angel » Mon Jun 09, 2014 12:08 pm
First of all I have a 3000 pound ride boat with a blower on it thats producing approx 3000 hp. Question is why ? Cuz I can !!! That simple.
Never have I even called any one out to race or did I say it was the fastest ride boat around. Dont even have the boat dialed in yet.
Carbs are off right now - found out they were too small had to get bigger ones which should be here today.
I imagine that once the boat is dialed in it will be a runner !!
Even those of you with "ride boats" weigh half of what this boat weighs.
Now lets get to the racing part ; I have been racing for 34 years and nothing has changed - there is always somebody crying about something or they're faster. Remember there is always someone faster....it's cubic dollars.
I have not daid I won't race you guys ; but this is all for fun - may just get my ass handed to me. But this boat is a customer request boat as he dont wanna get stuck and be able to go anywhere he wants.
I would love to come out and play around with some of you when ready. I wanna know what this boat will do myself!! This is a one of a kind build with inline 6 water walker falcon blades.I can tell you that there is no other blades that could tame this boat. Dont even know how its gonna come out of hole yet but I do know that I am gonna have plenty of power after 400 feet and all day long!!!!
I will keep you informed and when boat is ready to play still working on it.
Hoping to be in kissimmee July 4 weekend...?
:angel4:
yall are the ones keep talkin race ; I was just showing you pics of our newest ride boat.
DynaMarine
Postby DynaMarine » Mon Jun 09, 2014 1:53 pm
You have 1HP per pound of boat weight, that's more than just about any ride boat I know of including my own twin turbo LS which is .6HP per pound at best.
Racing is fun and having a unique boat will always draw attention whether you want it or not. Regardless of how fast she is, it's a cool project and no one can take that away from ya
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
airboat angel
Postby airboat angel » Mon Jun 09, 2014 2:51 pm
Well thank you very much Shane.
:angel4:
pontoon outlaw
Postby pontoon outlaw » Mon Jun 09, 2014 5:18 pm
:slap: the heck with all this race talk I want to see that beast follow me along the tree line :lol: from the looks of it I bet it will make it's own trail :thumbleft:
airboat angel
Postby airboat angel » Tue Jun 10, 2014 11:09 am
LOL !!! Now thats wht I'm talkin bout !!!
:angel4:
ls1airboat
Postby ls1airboat » Wed Sep 17, 2014 3:14 pm
can we all see a video of this 3000 hp boat ?...take videos and post them on here.
