Video of Unlimited Airboat jump today...
- Southern Airboat Member
- Contact:
You can see the on board footage we have from Brad Hendry's boat today at the race at our site. http://www.waterthunder.com/
You're better of lucky than good. Because no matter how good you are, until you get lucky, you're just playing with yourself. -The Dickens
- Southern Style
- Site Supporter - IV
Re: Video of Unlimited Airboat jump today...
Site didn't work....
KRVSA Member
SJRAA Member
KCCO
KRVSA Member
SJRAA Member
KCCO
- Contact:
Yeah, noticed that. Uploaded video. Tested and then make this thread and now it's not working. Timing is everything.
- Contact:
Okay, it's fixed. Give it a try now.
wow
- PAINKILLER
http://youtu.be/sq_kDb9cEoc WOW wild ride
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box
Crazy
tons videos on YouTube ptr34
- PAINKILLER
Thank God Brad or no one else was hurt . That father and son on 4 wheelers just sat there watching it come toward them.
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
2.68 Ox Box
82" 3 blade R
- farmboy
- Site Supporter - VIII
HOLY $HIT!!!! Damn that could have been VERY bad... I'm glad everybody's alright!
- Waterthunder
- Contact:
It stinks that happened that pass was the fastest official ET pass ever. It was the 1st pass in the 3's during competition. Whats even crazier it Sounds like there wasn't enough pitch in the prop that thing is banging the rev limiter all the way down the track you can hear it plain as day in the video.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
321-508-5316
- Bruce
- Contact:
whew glad brad didnt get hurt thats for sure and are my eyes deceiving me or did ronnie reach the finish first
12 foot Mamba "The Underdog"
- Waterthunder
- Contact:
Yes,,,,, because he is left before the tree even started, He red lighted real bad. If you watch the tree brad gets the win light as soon as the tree starts because Ron already left. Ron redlighted twice today and twice at the last race
321-508-5316
321-508-5316
I have a question. Once the boat starts to get airborne sorta sideways did it just come back down due to good luck or did he do something to make it happen? Not that I plan on ever doing anything to cause this to happen to me but I'd like to know if there is a way he specifically made this happen being an experienced racer.... Thanks
- Stewie
- Site Supporter - III
Whew glad everything went ok! He did a fine job on that rudder stick good driving!!!!
- Waterthunder
- Contact:
In the video you can see him steering it the whole time!
321-508-5316
321-508-5316
- HuntingBigun
- Contact:
Wow
Bigun
http://www.krvsa.com
It was crazy in person! I would say most definitely luck and him driving his butt off....
Temporary High
12' clendenin aluminum step with poly, 418 waterthunder, 2.68 OX, 9 blade saber, ATF rigged, nitrous outlet,, buttrax custom seats.
Temporary High
What caused this to happen? Glade no one was hurt
- AirRanger
- Contact:
Spectators along the bank are the lucky ones. If this had happen sooner in the pass we may be looking at the video in a whole different way.
Now that was one wild ride, and I think the pucker factor maxed out for the driver, and the spectators on the ATV's.
Glad everyone is OK.
- Gator Bait
I don't see how he was driving it u can see his foot is not on the gas at all after he hit the break and started his slide into the bank ,,, no wind from the prop on the rudders no steering right , I think he was just dang lucky ,, any way glad no one was hurt
As I lay Grass in the Glades I pray the slide will go my way, But if the wind takes over instead I Pray the Lord Protect My SLED
That particular boat runs what's called a barrel valve for the mechanical fuel injection. Something in that setup stuck and the throttle was in turn stuck around probly 3-4000 rpms..... things could have been way way worse then they were.
Temporary High
- Waterthunder
- Contact:
Something went wrong and nobody knows what YET,,, it's all pure speculation!,,,, I went straight to the boat and checked the barrel valve 1st it was not stuck but that doesn't mean anything. Barrel valves can become an issue when there is a large increase in fuel pressure however once the engine quits running there is no-longer any pressure on a barrel valve so there is no way to tell if it stuck. You can say I have some experience over the years with barrel valves and high speed leanouts. Many Top Fuel teams have an emergency fuel system shut off for over pressure problems such as this. Right now I'm down to 3 scenarios by the end of the week we will have the data required to address the problem. I can say one thing our tune right now is way off on motor and nitrous. I had a dozen people tell me how wrong we are doing everything so at the next race expect both our motors to be substantially faster. I'm amazed we even got Chucks to run with all the problems we had it was a very intense 5 minutes of me Shawn and chuck completely changing the nitrous, fuel system, timing and wiring.
Of coarse the main priority is nobody was hurt.
321-508-5316
321-508-5316
