Continental 520 putting 10 1/2 pistons in
riverrat1
Postby riverrat1 » Mon Jun 01, 2015 7:35 pm
So is it worth putting more compression in a 520. What would be the hp. Gain
Sniper25
Re: Continental 520 putting 10 1/2 pistons in
Postby Sniper25 » Wed Jun 03, 2015 9:52 am
When I had my 520 conversion re built I went with hi comp pistons. I had to put 7 degrees of pitch in the prop to hold it back. But this may be a little extreme bc my engine before re build was never really right.
14' Laser / 520 Cont.
Losing faith in humanity one person at a time!!!
Postby John Fenner » Wed Jun 03, 2015 1:03 pm
The difference is between a chimp or a gorilla. Well worth the investment and time spent, plus you will be getting to use the full advantage of 100ll avgas. Where as we don't have access to 87 octane avgas any longer.
fletchster76
Postby fletchster76 » Wed Jun 03, 2015 6:23 pm
The high compression piston most people put in a 520 are 8.5 to 1's correct? I've never heard of a 10.5 to 1 but would expect it to be a beast.
13'6" Laser, 520 conversion, 72" 3 blade ngh
mike520
Postby mike520 » Wed Jun 03, 2015 10:29 pm
when I built my 520 8 years ago I put 10 .5 to 1 pistons in it. awesome power to say the least. but no aircraft starter would turn it over. when it was all said and done had to make my own start cables and fabricate a flywheel. used a high torque chevy starter from jegs catalog. I dealt with Gibson aviation out of oklohoma
a.
riverrat1
Postby riverrat1 » Thu Jun 04, 2015 9:49 am
I was thinking of going with 10.5 motor is pushing 2750 on the trailer with a 2 blade Q just wondering if money.
