How about nitrous?
twister69z
How about nitrous?
Postby twister69z » Fri Jul 31, 2015 3:34 pm
Lycoming IO-540-K1G5D stock . With the exception of the injection converted to carburetor.
What % or amount of Nitrus would give a boost of power not radical enough to need a pitch change of the propeller but still get you unstuck from some sticky mud or grass? Not using this for racing just to get a boost when needed. I have abandoned using a add on supercharger,or Turbo. Should I worry about the mixture being too lean for the minute or so I am using the spray? Here is the place to help a fellow airboater learn from previous mistakes or conquests! Please,post here,
Twister69z
Also if you have recommendations of manufacturers of this setup don't hold back!
keebo
Re: How about nitrous?
Postby keebo » Fri Jul 31, 2015 5:16 pm
You can be safe with a 50 shot, just don't abuse it. You won't be holding the bottom for but a few seconds; will be all you need for what you described, be careful though it's addictive and runs out.
You will have a nos selenoid and a fuel selenoid feeding your plate so not to worry about lean, just have to set it up right and you'll be good.
I'll see if I can dig out my set up and plate for an MA4/5 carb and post a pic
[b]I'd rather answer your dumb questions now then fix your stupid mistakes later
13x7-6 Hamant, air ride and a little ol 180
twister69z
Postby twister69z » Fri Jul 31, 2015 10:40 pm
I would appreciate that a lot! Thanks for the reply!
How much did you gain ? And do you think it is at all,harmful?
Twister69z
keebo
Postby keebo » Sat Aug 01, 2015 9:28 am
I'd be guessing on the gains, I would say about 30hp gain plenty enough to give you that little extra oomph in a sticky situation. As far as harmful we have to be real, all power adders can be harmful, with a 50 shot it can last a long time without problems if not abused and the system is maintained. A bad fuel selenoid will give you a lean situation which basically turns your nitrous into a cutting torch on your piston. Not trying to scare you away from it, just giving you information. It can be on there for years used responsible or you can fry it quick.
HAMMERHEAD
Postby HAMMERHEAD » Sat Aug 01, 2015 8:43 pm
you can use a single fogger system and set it up very easy without having to build a custom plate, just drill and tap. you should use a separate fuel pump and regulator with your system and set the pressure at 6.5 PSI with an accurate fuel guage free flowing back into your tank with a # 73 holley jet in the fuel line for starters, you should be able to run a 100 shot safely on stock components if there are no current unknown damage internals. a good tune for 100 HP is a #52 nitrous jet with a # 48 fuel jet. ALWAYS BUMP YOUR SYSTEM WITH THE BOTTLE OFF TO MAKE SURE THE FUEL SOLENOID IS FUNCTIONING BEFORE RUNNING THE SYSTEM ON THE BOTTLE, THIS WILL ALSO PURGE THE FUEL SYSTEM. the 100 HP tune up is based on a 350 CI Chevrolet, it is probably more like 50 to 75 HP on your 540. A minimum of AV GAS is required and timing should be considered. you should be ok with 26 degrees with good fuel with this tune but if you increase the tune you would need to retard timing. If you are set up to turn around 2900 RPM on motor you should not need to increase pitch if you are just using the system to get out of a sticky situation. GOOD LUCK!
Postby SWAMPHUNTER45 » Sun Aug 02, 2015 9:02 am
Octane, fuel presure and timing are without a doubt critical elements in setting up an NOS.
I suggest you plan to add a seperate arming switch to prevent accidental activation. If you are going to use a driver activated push button then you need to develope a routine to ensure you dont screw up the sequence of events.
STEP 8 requires you to think!
1) verify fuel pressure / purge
2) NOS valve open
3) check engine guages
4) Arming System
5) 360' scan boat and area around you
6) bring engine to full throttle
7) activate NOS
8) release NOS button - before you lift foot off gas
9) close arming circuit
10) post use inspection / close tank valve
twister69z
Postby twister69z » Tue Aug 04, 2015 10:21 am
Thank you for all the replies! I think we are going to " give it a shot!"
The cylinders are fresh Cermanil cylinders should be a good combination for the nitrous shot!
Twister69z
keebo
Postby keebo » Thu Aug 20, 2015 6:48 pm
Twister, posted pic in my album pm' you specifics
stroked470
Postby stroked470 » Thu Aug 20, 2015 8:08 pm
This is one I built. Exactly as Dwayne said
keebo
Postby keebo » Thu Aug 20, 2015 8:27 pm
Looks good
stroked470
Postby stroked470 » Thu Aug 20, 2015 8:54 pm
There are more pics in my gallery of it.
twister69z
Postby twister69z » Fri Aug 21, 2015 7:28 am
Thanks!
air-roberts
Postby air-roberts » Fri Aug 21, 2015 8:14 am
x2 on hammerhead
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
