HP Guru
pristinewater
HP Guru
Postby pristinewater » Wed Jan 20, 2016 8:01 pm
Are there anything that can be done to kick up the HP on a 0470-11 and if so, how much more.
Thanks
JT540
Re: HP Guru
Postby JT540 » Thu Jan 21, 2016 1:29 pm
you can put the o470 r pistons in it and make more compression but the cam that's n those are not very good. if you wanted to go all the way down and replace the cam with a cam from a e225 that would be a lot better. you can also bore the case and put 520 cylinders on them but again that's going all the way down and complete overhaul.
